Old 06-02-2019, 01:32 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
https://albuquerque.craigslist.org/a...881876757.html
I think I can tweak it to tune out to 108 Mhz
Old 06-02-2019, 02:31 PM
Telecolor 3007's Avatar
I love old stuff
Oh, it's a stationary
160 bucks is pretty much for such radio.
Yes, it can be make to work up to 108 M.Hz.
Sailor Moon
Old 06-11-2019, 12:12 PM
I love old stuff
For the ones owing such a radio: how would you describe the radio performances of it?
Audio ones I guess wheren't on the top...
Sailor Moon
Old 06-30-2019, 01:20 PM
Josef's Avatar
Josef Josef is offline
Originally Posted by Telecolor 3007 View Post
1st times I've read Australia and I wondered how come portable tube radios with F.M. in 1957 since in Australia F.M. camed only in 1975.
But it was Austria. The radio had 5 or 6 tubes for radio frequency as I can see. Most had only 4. How did it worked on radio? And what F.M. frequency range it had?
I finished the restoration of the hybrid set 2 weeks ago. It's now possible to directly compare the tube version with the hybrid.
Both sets work surprisingly good, espcially the sound quality of the tube set is impressive, even though the output tube is not really strong to save battery capacity.
To the restoration: Both sets usually have massive problems with a built in rechargable battery which leaks out it's acid that causes a lot of corrosion usually. Also the handle is usually broken as well as the antenna.
Finding a good example can be time consuming and expensive too also these radios are quite wanted and sell fast usually.
Old 06-30-2019, 04:19 PM
Would LOVE to see an inside pic of that Bad Boy... Your example is GORGEOUS, in any case...
Old 07-01-2019, 02:10 PM
Josef's Avatar
@Sandy: No probelm, here we go:
The aluminium box in the lower right of the first picture is the shielded DC/DC converter. The circuit on the Pertinax board are the insides.
As you can see this radio is hand wired and quite well made. The cabinet is made of wood covered with a colored plastic foil.
Not to mention that you could buy 3 small FM only mains powered tube radios for the same price back when this set was new
The leaky waxies are already replaced with axial styroflex and mustard caps in these pictures.
I bought this radio from the widow of a well known radio collector who passed away some time ago. So there also is some sentimetal value in this set.
Old 07-01-2019, 03:22 PM
Danke, Josef ! I have a few German AM/FM/SW sets, & marvel at how mainly, they did everything w/just 5 tubes, too. American sets, to the best of my experience, pretty much always used at least 6 or more often 7.
Old 07-01-2019, 03:47 PM
Josef's Avatar
Bitte sehr!
The tube set also has 7 tubes, but the hybrid needs only RF and IF tubes because the AF amp is already transistorized.
Old 07-13-2019, 07:21 PM
I love old stuff
But if the bateries leaked (sheesh, I can't imagine how is to have leaks from an anodic battery) the electrolite impregnated into the wood of the case it can be a problem or it dosen't smell bad?
Did you ever seen and Austrian tube portable radio that had F.M. (U.K.W.) 88-108?
Sailor Moon
Old 07-21-2019, 03:15 PM
Josef's Avatar
The leaked out acid causes excessive corrosion on the aluminium chassis and discolors the wood. The problem is that there is a built in NC battery which leaks terrible. So event though if you remove all batteries you can't avoid the built in battery.
At least there is no smell left over because everything is dried out since ages.
To be honest I don't know an Austrian tube portable radio up to 108 MHz. Even though early transistor radios went up only to 100MHz.
Mains powered tube radios which went up to 104 MHz were available in the early 1960.
Old 07-28-2019, 07:56 PM
zombie1210's Avatar
zombie1210 zombie1210 is offline
Tubes. FM.
Old 08-19-2019, 12:27 AM
TV-collector's Avatar
TV-collector TV-collector is offline
About all german companies made tube radios with FM. They all work very well.
Akkord made only!!!! portable Radios.
I own the rare manual incl. all Akkord radio stuff.
Regards,
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
Old 08-21-2019, 06:34 PM
I love old stuff
zombie1210 , your radio is not portable, but is't very nice!
Sailor Moon
Old 05-10-2020, 07:38 PM
I love old stuff
Anyone else?
Sailor Moon
Old 11-05-2020, 12:15 PM
I just bought a Grundig Transworld on Halloween while buying a couple of Philco TVs.
It was for sale, the first tube FM portable I've seen in person, and the price on the lot of items was right.
I brought it up on the variac and got hum and tubes lighting but no reception.
I need to find a schematic and dig into it.
