Old 04-10-2019, 10:23 PM
I don't believe it.
I have started to try and check resistors in my set. (it sucks that most cant be tested in-circuit)
started checking and ran into trouble right at the start.
AGC line r36, 2.2 meg could not measure it with this cheap RS meter I have.. Off-scale high/ almost reads 20m on the 20m setting (no other higher) it cant be THAT far off
So it's
A: the cheap meter is lying to me and cant be trusted, or B: it really IS over 10x too high..
taking this resistor to work to check with a $400 fluke I have there.
Also getting another cheap autorange meter that goes up to 200m.
Old 04-10-2019, 10:34 PM
https://imgur.com/KHo8VmG
mine
Old 04-11-2019, 12:23 AM
Resistors tend to drift high (sometimes even open) and ones that start high tend to be worse so I tend to believe the meter...
Be GALD your set did not spend it's life outside getting rained on/in...I found a 1972 Sylvania in a ditch once with the amount of rust in its metal table model cabinet, rot in the back and lawn debris inside it I was sure the only good part would be the CRT...But then I washed the crap out and decided to 'play' with it. Somehow with little effort, it made a raster...Getting anything else out of it meant replacing 95% of the resistors in each stage (most were wildly out of tolerance). Somehow it made a damn good pic and decent sound for a while after re-resistoring it.
Old 04-11-2019, 11:54 AM
I just ordered an assortment of ˝ watt metal film resistors (not carbon film, too high rfi ) Which should have most of what I find bad, I hope.
The resistor I tried to check last night checks at 31m , out of range of the cheap meter I had.
the new cheap meter coming goes up to 200m.
Someplace, somewhere, in my home is hiding a Fluke 73 III...
And I suspect that when I LEAST need it, is when it will crawl out of it's hiding place in the 6th dimension, where it has been the last 6 or more months and reappear.
Old 04-11-2019, 06:56 PM
Rocket's Avatar
Rocket Rocket is offline
VideoKarma Raccoon
Nice looking chassis! looks to be in decent shape and not much rust or anything : D
Old 04-11-2019, 07:05 PM
Rocket's Avatar
VideoKarma Raccoon
I don't believe it.
So it's
I have also ran into this myself a few time. I have had some resistors in a few of my old zenith radio sets that were meg omhs instead of low k's
also a while back I got this Klein meter, it isn't as nice as a 400 buck fluke, but its close. I love it a lot more than my old 20 dollar digital I had and it can test up to 1000vdc/vac and I have found that handy working on some of my old radios.
check it out, its just under 100 bucks
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Old 04-11-2019, 07:13 PM
https://imgur.com/sob7yID
this is where my CTC spent the last 13 years or so,
and before that it was rented storage spaces, so it was always kept covered.
Old 04-11-2019, 10:41 PM
Rocket's Avatar
VideoKarma Raccoon
Nice! glad it was kept out of the weather
im looking forward to seeing pictures of your set when you have it running
Old 04-12-2019, 02:12 PM
SAMS makes it really hard to find R34,35,36 mounted on tuner :/
All they give is an overhead shot of the chassis / tuner ( page 17) with arrows pointing to a dark fuzzy low res area of where they are, no zoom of the area with the resistors marked :/
Old 04-13-2019, 06:29 PM
Have started on the sweep PCB. around the AGC/ sinc sep circuit.( takes a LONG time :O )
https://imgur.com/vKACCKZ
seems that 15% of the resistors are out of tol so far.
Old 04-14-2019, 07:10 PM
Bill R Bill R is offline
Keep this in mind when checking resistors. There is nothing that will make a resistor read high, other than a bad resistor. Any other parts of the circuit, ie: parallel paths, will cause a lower reading. I always check in circuit and if it is low then I remove it to check it. If it reads high, I just replace it. Since most resistors drift up in value, there is usually no need to take a resistor out of circuit for an initial test.
Old 04-14-2019, 08:11 PM
Originally Posted by Bill R View Post
...Since most resistors drift up in value, there is usually no need to take a resistor out of circuit for an initial test.
There are occasions where a resistor will drift down if it's the older phenolic-encased type. If the resistor's been running hot for a long time, the phenolic case will gradually char from the inside and create a conductive path around the resistance element. Most often seen in one and two watt units.
Old 04-14-2019, 08:50 PM
i just wonder how critical i should be, i am seeing some WELL within the 20% range, and others just over /under and some WAY over. I tend to want to replace the ones not "well within range...
Old 04-14-2019, 09:01 PM
If you are looking at carbon composition resistors, you should know that the 5% ones and 10% ones often were picked out at the end of the production line, leaving the 20% ones always worse than +10% or -10% (a "bimodal" distribution).
Old 04-14-2019, 09:07 PM
Also if the 4th tolerance band exists; base the acceptable tolerance on that. Usually on 60's color sets the majority of resistors will be 10% silver bands with some 5% gold for critical apps and some 20% no-4th-band resistors thrown in non-critical areas for cost savings.
If a gold band checks within 10-20% but not in it's designed 5% and you leave it, then you just missed a failed component...
