Old 11-29-2018, 10:59 PM
Titan1a Titan1a is offline
It looks to me like a keeper. It's fairly rare and has good reception.
Rick (Sparks) Ethridge
Old 11-30-2018, 12:34 AM
3-gang tuning cap. Doesn't look like there's an RF stage, though.
Old 11-30-2018, 12:13 PM
Originally Posted by init4fun View Post
Were the ballast tube burnt out and unobtainable sure I'd run an AC capacitor in it's stead and not think twice about altering the circuit , in my opinion running condition trumps original condition with most tube radios . But , since I'll bet replacements for the original ballast tube are still available , and since the ballast tube carries no built in safety hazard by design like the curtain burner cord does , I'd be inclined to leave the circuit as is and stock up on a couple or few spare ballast tubes while they are still somewhat available .
If the ballast tube is readily available and reasonably priced, then fine. The 165R8 number seems to be a Triad or Hytron number. JFD numbers are different.
When the set was new there was a lot of DC districts, so a resistive dropper had to be used.
Old 11-30-2018, 12:22 PM
Wells-Gardner used a four-gang tuning condenser in their high tube count superhets. It seemed that the fourth section was used as some sort of an antenna pre-selector.
I looked at the schematic again and it's not being used at all. I thought maybe, as they built that set as a long-wave model, they used it, but they didn't!
Possibly a chassis layout or an inventory reason.
Old 11-30-2018, 01:35 PM
decojoe67's Avatar
Originally Posted by zombie1210 View Post
Curtain burner line cord? Sounds ominous.
I've had many working "curtain-burner" radios in my many years of collecting and you could literally lay the cord in a pile of dry paper shreds and nothing will happen. Even after long play time it only gets moderately warm. Pure urban legend that it will burn the house down.
It's the same urban legend with the sheet of asbestos on the top of the inside of the radio in which you better put your Hazmat suit on and dispose of it before it sends you to an early grave!
Old 11-30-2018, 05:12 PM
That's been my experience with 'em also. The gripe is more on the cheezyness factor than any real hazard.
Old 11-30-2018, 08:09 PM
decojoe67's Avatar
I agree. I like those sets with their original thick cloth cords. Right now I have about 5 that work excellent.
Old 12-01-2018, 07:45 AM
init4fun's Avatar
init4fun init4fun is offline
Old 12-01-2018, 11:27 AM
The real cheap and nasty four tube TRF's were referred to as "Depression radios". They all used the resistive cord droppers and many were sold for around $10 USD. Many of the ones I ran into the cord was damaged one way or another. Most of the time the resistance wire was pulled loose from the plug connection and the plug was replaced.
If the cord was in good condition in later years, many times the resistance wire was rusted open as the wire was some kind of an iron alloy for ballasting action, just like the ballast tubes had.
Old 12-01-2018, 11:33 AM
If the builder of the product wanted U/L listing, they couldn't get it on a set equipped as such.
Old 12-01-2018, 11:08 PM
decojoe67's Avatar
I'm sure of that. It definitely isn't the greatest idea, but the severity of it has been a little exaggerated over the years by collectors.
