Old 01-06-2018, 09:50 PM
targeteye's Avatar
targeteye targeteye is offline
ok so understand this is the only "vintage" tv I have ever messed with ... I had to go find an old DVD player and fix it it first (the mechanisms were sticking from non use). Got it working and scrounged up an RF modulator I remember I stowed away "just in case I ever needed one ?>
Then I had to scrounge for a non-widescreen DVD!.. sheese.. could only find the Wild Thornberry's.
Well, now to figure out if I want to build a quick 24vdc supply or look for another junker tv to rob a FBT out of.
Also, I clearly have no idea how to take a picture of a TV
Steve
looking for technics turntables to gramophones.
Old 01-07-2018, 12:20 AM
Perhaps figure out the turns per volt ratio of the transformer and add a new winding for the 24 volt supply.
Old 01-07-2018, 01:19 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Neat. Just throw a small power supply in the case somewhere lol
Old 01-07-2018, 08:45 AM
Never had a pulse winding open, most unusual. At the time
Sonys with ADD/DEL on hand unit had no universal sub.
You may be able to random access any channel but I just
dont remember.
Old 01-07-2018, 09:31 AM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
Originally Posted by targeteye View Post
... I had to go find an old DVD player and fix it it first (the mechanisms were sticking from non use). Got it working and scrounged up an RF modulator I remember I stowed away "just in case I ever needed one ? ..........
Steve
What i don't understand , I have an old RCA 1979 B&W and i can't put a DVD to my tv !! is there some tricks or ??
Old 01-07-2018, 10:46 AM
targeteye's Avatar
Good suggestion but i think it would be easier to just install another supply considering the mechanical construction of the FBT.
Steve
Old 01-07-2018, 11:25 AM
targeteye's Avatar
dont remember.
The ADD/DEL is on the TV, you just need the remote to punch in the channel, then push ADD on the TV.
Steve
Old 01-07-2018, 11:43 AM
targeteye's Avatar
You need one of 2 things.
1. A DVD player with modulated RF output. I suspect not many of these were made... if any.
2. An external modulator such as the one in the picture. It takes composite video, and L/R Audio and modulates the information on to usually Channel 3 or 4.
The modulators were produced by the gazillions when things like DVDs and VCRs stopped installing internal modulators and folks still had old tv,s that excepted only RF input (or had a limited number of inputs). Just search Ebay for Television RF modulator. You can now get them for very little money.
Now .. like I said i'm brand new to the "old tv" scene. Is there something about a B&W set where this will not work? I don't think so but perhaps someone more knowledgeable will chime in. I vaugely remember something about copyright protection messing with the signal to prevent duplication but I think that was on VCRs.
Steve
Old 01-07-2018, 12:48 PM
Marco-nix's Avatar
Steve
Don't worry, my B&W tv's working fine.. i have the RF output but not the device in the picture. So i should buy one..i just can watch my tv with a VCR(VHS)...
Old 01-07-2018, 03:34 PM
Steve
Macrovision copy protection existed on both VHS and DVD. Only some recordings had it, some players and external boxes eliminated it. Older TVs (pre-1980) sometimes were bothered by it.
Old 01-07-2018, 04:45 PM
targeteye's Avatar
The project comes to an end.
Well folks its been interesting and a learning experience.. .
Installed an external regulator. Worked like a champ!
Then a test lead falls into a circuit and poof.. Fried circuitry .. bummer.
oh well. I'm going to put this in the attic and look for a working version of the same model and save this one for parts.
Steve
