Old 11-20-2017, 02:00 PM
Yes, I'm surprised you ask. I know you've replaced them in Motorrola VT-71s.
Selenium rectifiers gradually increase in resistance over time even when not used. Eventually, they fail in a big cloud of very foul smelling smoke. Took days to get the smell out of my place last time it happened
Old 11-20-2017, 03:06 PM
What I mean is it important to use resistors with the diodes.
Old 11-20-2017, 05:49 PM
The 12dq6 and 12dq6b are these for the most part the same, could it be used in the admiral which had the one without the b .
Old 11-21-2017, 09:17 AM
I don't know for sure. Definitely if you don't use them B+ will be higher than specified - especially if your AC outlets are more than the 117 VAC it was designed for. I'm use something like 47 to 100 ohms 5W and see how B+ measures once the set is up and running.
Yes, generally speaking tubes with A, B, C etc suffixes have superior specs to the earlier version and can sub for them.
Old 11-21-2017, 09:39 AM
Do you know what the b+ voltage is on that admiral ?
Old 11-21-2017, 10:28 AM
Main B+ is 255 volts going by the SAMS. Go to the ETF site and download the folder for the tv. Tom.J
Old 11-21-2017, 11:09 AM
I read bandersens thread on the same tv I have, and he changed the dual diode because of lousy horiz lock and I'm wondering if I could use a dual diode that are normally in the color sets the small black block with the 3 legs. If I should need to change it.
