Old 07-01-2017, 09:23 AM
nasadowsk's Avatar
Damn does run fast…
I think SMDs would lead to a smaller package, and then you could epoxy dip it for an authentic look. And better reliability.
My only question is, can they take any voltage spikes on them? This might be an issue. (Don't forget startup, before the tubes are conducting...)
What are you using for the PCB design, btw?
If there was enough demand, you could get them made by a PCB place and stuffed and all. With the plethora of places overseas, this is surprisingly cheap now...
Old 07-01-2017, 03:05 PM
Notimetolooz's Avatar
On K7 the junction of the 560 pf and 3300 pf needs to connect to pin 2.
I wish the schematics were drawn easier to follow, more nearly like your layout.
Old 07-01-2017, 06:31 PM
Good catch! I missed that one on my first look. Like the way the distributec R/c was done in k4.
Old 07-01-2017, 08:14 PM
Wow, I missed that there was a connection there! Thanks.
Old 07-02-2017, 10:52 PM
I made the PCB's today. Basically I use the Press-N-Peel method. Or another name is Toner Transfer. I run the sheet through my laser printer set on 1200dpi and the iron on the pattern on a clean, really clean copper side of the board. Peel off the sheet, then etch, drill, and trim to size.
Here are the boards with the toner transferred to the copper.
Old 07-03-2017, 02:30 AM
Here they are. Ready to encapsulate. Can you find the 82pf 200V cap?
Old 07-03-2017, 12:47 PM
Nice work!
Old 07-03-2017, 02:54 PM
Thanks Tim.
Old 07-03-2017, 08:44 PM
irext's Avatar
irext irext is offline
Very neat. Would you bother to encapsulate them? They look very nice as is. Other than authenticity I can't see a reason to. In the (admittedly highly unlikely) event of a component failure you can replace a component if left unencapsulated.
Old 07-04-2017, 12:24 PM
Very nice!
Out of curiosity, where is K8 located in the set? I don't remember seeing it when I did mine a few weeks ago.
Old 07-04-2017, 01:51 PM
Yeah, I thought of leaving them as they are. But then encapsulated them.
Old 07-04-2017, 01:53 PM
Very nice!
Thanks. K8 is located on the top of the main chassis. It goes between the main and CRT chassis. Looks a lot like a ceramic disc capacitor.
Old 07-04-2017, 02:07 PM
Slaps forehead!
I remember unsoldering a "ceramic cap" when I pulled the chassis... since I generally leave ceramic caps alone, I paid no attention to it.
Old 07-04-2017, 02:37 PM
Slaps forehead!
I thought that might have been the case.
Old 07-04-2017, 03:15 PM
Ready to solder in!
The paint I used.
