Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 03-26-2017, 05:35 PM
TUD1 TUD1 is offline
Tuner cleaner!
Since Radioshack is EOL'ing, I no longer have a source for their Cleaner and Lubricant which I have found is marvelous for making controls and tuners work like new. Does anybody know a good substitute for this stuff?
Old 03-26-2017, 05:53 PM
I usually use this:
https://www.amazon.com/DeOxit-Cleani...eywords=deoxit
not affiliated,
Old 03-26-2017, 06:19 PM
Well I have a can of the "normal" Deoxit, but it doesn't seem to have any sort of lubrication agent. Maybe this stuff is different.
Old 03-26-2017, 11:18 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Down to my last 1/4 of the rat shack stuff myself and our store is LONG GONE...
SR
Old 03-27-2017, 12:01 AM
Early discussion of Deoxit vs R/S contact cleaners:
http://www.videokarma.org/showthread.php?t=65178
D-5 feels fairly oily to me, but sometimes I use Deoxit "Gold" or "Fader Lube" as needed.
Old 03-27-2017, 12:18 AM
I was going to say good luck since the envirofreaks with their BS and watching out for these chemicals.
I'm glad that Amazon still has some left.
Old 03-27-2017, 07:45 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
If some lubricant is needed after cleaning with the D5, I follow that up with a little shot of Caig's "Fader Lube".
Old 03-27-2017, 07:49 AM
Findm-Keepm's Avatar
Followin' the Rules...
Just about every distributor in the 80s and 90s had their own branded contact and tuner cleaner, courtesy of Rawn Chemicals. Their sales guys would hand out samples of cleaner spray to just about anybody that walked into the distributor. 6 weeks later, and folks were back to buy more.
MCM still carries the Rawn Contact Cleaner - I use it with my stuff, along with Caig D5 for other folk's stuff. The Rawn lasts 3X longer (bigger can), and works great:
http://www.mcmelectronics.com/produc...11118-/20-2005
For totally degunking a tuner (too much tuner lube, disintegrated lube pad, frozen/dried out grease), this stuff from Caig works miracles:
http://www.mcmelectronics.com/produc...8-657063315CBF
I've used both products and recommend them - been working TVs for almost 40 years, and they are the best I've come across, save the stuff from Allied Chemicals, no longer in business (thanks Kepone....).
Stay away from Chemtronics - they change formulations without changing labels......
Brian
USN RET 22YRS (Avionics/Cal)
Old 03-27-2017, 08:52 AM
I looked on Caig's website, and apparently they made the "Cleaner and Lubricant" for Radio Shack. I bet it's wheel similar to one of the Deoxits. .
Old 04-11-2017, 06:14 AM
tvdude1 tvdude1 is offline
I use brake cleaner works mint and only 6 bucks a can.
Old 04-11-2017, 06:56 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Brake cleaner will melt plastics and dries out any lubricants in the pot. I use DeOxit D5 myself. For some applications, CRC Lectra Motive cleaner works very well also.
Old 04-11-2017, 08:40 AM
I can get a can of De-Ox-Id (a cheaper and comparably effective alternative to deoxit) for that price.
I rather use a purpose made contact cleaner (especially around plastic and phenolic parts) where ever possible...In a pinch WD-40 will work as a control cleaner and lube. I also will use it whenever I encounter a stuck control shaft or a pot that badly needs some lube.
Old 04-11-2017, 09:42 AM
maxhifi's Avatar
maxhifi maxhifi is offline
I used to always buy radio shack contact cleaner, but the last can was garbage. Now use MG chemicals products.
Old 04-11-2017, 05:56 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I had a can of DeOxit D5 one time but didn't like it because it is so oily. I just got a big can of MG Chemicals Electrosolve and tried it on my Sanyo's VHF tuner, fixed it right up. I tried Radio Shack's trash on it a while ago which made no appreciable difference. Before the Electrosolve treatment I couldn't keep it locked on a signal.
Seems Electrosolve is basically a purer form of Nu-Trol; no lubricating agent I know of so it doesn't leave oily crap everywhere. It's far cheaper too, and my can was about half the price of what Amazon has. It's popular stuff, there were no big cans left on the shelf at Jentronics, someone had to go into the stockroom to get more.
I also sprayed the tuner and just about every chassis connection in My Electrohome just for good measure. Next up are my receiver and oscilloscope.
Old 04-11-2017, 11:41 PM
I know a guy that used WD40 on controls and tuners..Is that a degreaser and screw up some plastics.
I remember getting in sets and see green stuff around the controls and tuner.I use to know what the stuff used and now draw a blank.
