Old 05-30-2016, 11:46 PM
matt99 matt99 is offline
Level 1
Originally Posted by TUD1 View Post
I suppose I should change my signature, huh?
Hell no. Why stop at one?
Old 05-31-2016, 07:50 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Nice looking set. You'll soon discover that having only one isn't enough, space permitting.
Old 05-31-2016, 08:52 AM
TUD1 TUD1 is offline
I have an idea...
Old 05-31-2016, 09:02 AM
Level 1
I have an idea...
Perfect
Old 05-31-2016, 10:33 AM
Here is a picture of the Admiral TV chassis.
Old 05-31-2016, 10:34 AM
Also do we have any information on this seemingly generic RE21FJP22?
Old 05-31-2016, 10:51 AM
The first generation Admiral chassis. IIRC, they made it for two years. They even made a rectangular set, with that chassis. The color circuit was an RCA design. The next models were cheapened and used the 6LE8 type color circuit. They even made a roundie with the newer chassis, BOTL.
The amplifier in your set is respectable. It's amazing how good the SE 6BQ5's sound.
Old 05-31-2016, 11:00 AM
WISCOJIM WISCOJIM is offline
I believe the "RE" indicates that it is a "Rare Earth" phosphor tube.
Old 05-31-2016, 11:11 AM
I already knew that. Sorry. What I meant was do we know who made it or if it's original to the set? AEI kind of sounds like Admiral Electronics I????
Old 05-31-2016, 03:10 PM
jstout66 jstout66 is offline
Tube is a rebuild. Perhaps a rebuild from a local company?
At one time, Omaha had a handful of picture tube rebuilders, so I wonder if there was a local rebuilder in the area this set was found?
Old 05-31-2016, 06:01 PM
Yeah, Danny did say it was a rebuild. I just remembered that. Here is a picture of the AM/FM stereo. Interestingly enough, the "Pull on push off" treble control is just a standard turn-click switch. Oops.
Old 05-31-2016, 06:08 PM
Old TVs are better!
Did somebody say cataract? It's so bad, I don't think I'll have any issue getting the glass off.
Be very careful if you are going to try and remove the safety glass on the front of the CRT. I have never done it myself, as I've always have been afraid of imploding the tube. I know others have done it, successfully though. Read up on the procedures that they used and be VERY Careful. I don't think anyone on this forum wants to hear that your in the hospital getting stitched up from imploding glass. Also test the tube first to make sure it's good, and that is has good emission before even trying to remove the cataract.
Old 05-31-2016, 07:09 PM
I've watched every single cataract video on Youtube about five times each. I'm going to practice on a couple of junk tubes before going to the real deal. One with the water method and one with the heat.
Old 05-31-2016, 08:34 PM
Level 1
I could be mistaken but it looks like 0479 is stamped in red over the green print on the label. Would that be a rebuild date of April 1979?
Old 05-31-2016, 08:58 PM
Tom9589 Tom9589 is offline
Someone could have easily replaced the pull on push off switch with a conventional twist on switch. The twist on switches were a lot easier to come by than the pull on push off switches.
