Old 05-18-2016, 05:05 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Three legged thermistor on a CTC-53?
Picked up a CTC-53 portable recently, and while giving it the once over, I spotted a weird thermistor with three leads towards the back of the chassis near the picture tube. Almost looks like a big integrator. The leads were separated. Never seen one before. Talked to a friend and said that those were a common failure point but he couldn't remember what they do.
In lieu of a Sams on this set, does anyone happen to remember what they do, and what would serve as a replacement?
Old 05-18-2016, 08:20 AM
miniman82's Avatar
First Light: 1952-2011
Sure it's a thermistor and not a three legged MOV?
Evolution...
Old 05-18-2016, 09:11 AM
IIRC, it's in the deguass circuit.
Strange thing, my basic CTC51K, 14" similar chassis, doesn't have a deguasser, never came with one.
Old 05-18-2016, 09:49 AM
Kamakiri's Avatar
Might be, I've never seen one before so I'm not certain.
That's what Ed was thinking, something in the degauss circuit. I had thought of just unplugging the degauss and try firing it up. Might not be a bad idea to get a Sams on it first though to be on the safe side.
Old 05-18-2016, 11:35 AM
BigDavesTV's Avatar
BigDavesTV
Hey Tim, That is a three-legged thermistor, and is part of the Deguass Circuit. It's like two, 120 ohm thermistors back-to-back, for a total across of about 240 ohms. I have an extra N.O.S. in the package spare, if you want it.
Old 05-18-2016, 11:46 AM
rca2000's Avatar
rca2000 rca2000 is offline
I seem to recall those 3 leg thermistors being used on much newer SS sets. I THINK...one is right across the power line--designed to quickly heat the other one--which is in series with the degauss coil as usual. If they short--it WILL put a short on the AC line--at least it did on some SS sets.
I usually just omitted the second thermistor--if I could not get an original, put a standard PTC in the ckt in series with the coil--and the degauss ckt worked fine after.
Old 05-18-2016, 12:38 PM
Kamakiri's Avatar
That'd be awesome, really appreciate it Dave!
As a sidebar, can I just unplug the coil to test the set, or should I wait and install the replacement first?
Old 05-19-2016, 09:59 AM
For a CTC53H or K OEM is #127227
Its 2X 250 ohm cold. You can resolder them in a pinch
if the discs are in good shape.
