Built a SDR
Decided to build an SDR tonight, based off the vulnerable RTL-2832, and sought to built it the most reliably possible, and keep it completely shielded from outside noise.
So I built this box. I ended up using a DSUB for the USB connection because I was not satisfied with USB connectors, keeping RF out (except through the F-type input). As you can see from the screenshot, noise level is extremely low, almost completely flat. Signal is strong. It has two operating modes, standard, for 24 – 1766 MHz. And "direct" for 0-14.4MHz (though not as sensitive / also through modded drivers). I'm quite happy with this little box. It took me a better part of my night to do it though, and many beers, getting the grounding right. But alas, here we are! ![]() http://i.imgur.com/EBBVglL.jpg http://i.imgur.com/dvcVNhB.jpg http://i.imgur.com/MfUa0qk.jpg http://i.imgur.com/vngNq38.jpg Without Antenna (To show how shielded the SDR is): http://i.imgur.com/DO4ytSW.png With Antenna: http://i.imgur.com/XvaJ0yF.png Last edited by lnx64; 05-14-2016 at 12:39 AM. |
