Old 04-15-2016, 08:34 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
1968 Westinghouse JetLine
My neighbor gave me this 1968 Westinghouse JetLine tv. It keeps blowing the fuse attached to the line and the power transformer. I'm not used to working on these transistor sets, any idea what's causing his?
Old 04-15-2016, 08:40 PM
Here is the photo of the chassis. It uses a 19CMP4 crt. I don't have the schematic for this set yet. Has anyone worked on one if these sets?
Old 04-15-2016, 10:10 PM
maxhifi's Avatar
maxhifi maxhifi is offline
There's a short somewhere.. Try a variac ?
That is a very stylish tv, what a cool find!
Old 04-15-2016, 10:29 PM
I did a continuity check on the electrolytics to see if any of them are shorted and I get continuity on several. This could be my problem... I'll order replacements and restuff them and see if I get any success. It seems odd though that a set this late would have that many bad, but I guess it is 50+ years old.
Old 04-15-2016, 11:39 PM
slowly bringing it up on a variac and I finally am seeing some life at about 40%.
Old 04-15-2016, 11:58 PM
What amperage rating are the fuses you're putting in?
Old 04-16-2016, 12:14 AM
Found a silicon diode in the hv supply get hot at 30%, so I replaced it with a new one and replaced the hv rectifier. The set works great now!
Old 04-16-2016, 01:01 AM
Popester's Avatar
Popester Popester is offline
CRT looks like it has weak emission. Not to bad otherwise.
Old 04-16-2016, 09:35 AM
Rare & cool set. Was the first instant on set. I remember the
TV ads for it. Only saw a few on the bench.
Has the classic soft CRT look but be sure the instant on is
working OK. It may have a gang on/off SW where one part
fails. Common in the olden days. A very nice find that any
of us would like.
Old 04-16-2016, 10:08 AM
Thanks Zeno, cool info on it! The CRT tests way into the goid section, I just like running my tvs not do bright, plus there's that gig filter on the front too. I had never seen one before and thought it was a cool looking set.
Old 04-16-2016, 10:28 AM
I never knew they made that set solid-state. It was toward the end of Westinghouse's TV production. Looks overbuilt!
I had one, about two years older, all tube. Hot chassis, voltage doubler, probably TOTL and a great performer. Seemed to be a low hours set, CRT perfect!
Old 04-16-2016, 11:17 AM
WISCOJIM WISCOJIM is offline
I'm assuming by "gig filter" you meant the glare screen on the front. Never heard the term "gig filter". What does that mean? (Saw nothing that seemed to make sense using Google.)
Old 04-16-2016, 11:18 AM
The gig filter sounds like a real innovation.
Wunner if they had a patent on it.
Old 04-16-2016, 11:43 AM
Sorry guts, dang autocorrect! I meant fogged or smoked plastic screen cover.
Old 04-16-2016, 05:33 PM
The "sun screen" made the set look like it wasnt a TV when
off. It was like magic when you turned it on & a bright
picture appeared.
Tube models were more common but still not every day sets.
This was a big $ set.
W was about to pull the plug on consumer electronics at this time.
Personally I hated them but this is IMHO is a milestone set.
W had the ability to build very hi tec stuff but CE was a $$ looser.
IIRC they built the camera that showed N. Armstrong stepping
on the moon.
