Old 04-10-2016, 06:05 PM
Looks like your vertical deflection circuits aren't working. Instead of a full raster from top to bottom, you have the classic horizontal stripe.
Don't run it for long periods with that bright horizontal line, or it may burn a dark strip across your CRT.
Have you replaced any parts on this TV? If not, caps in the vertical seem like a good starting place.
Phil Nelson
Phil's Old Radios
Old 04-10-2016, 07:45 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Yes all caps, including the electrolytics, have been replaced. And I thought this was going to be an easy set...
Old 04-13-2016, 12:25 AM
This is the best I can get it. Any changing of the ion trap, yoke or focus coil only makes it worse or gives me a horizontal line. I'm confused on what's happening or where to look next....any thoughts here?
Old 04-13-2016, 12:34 AM
Check the resistance on the vertical output transformer and yoke.
