Old 03-02-2016, 02:40 PM
Regarding the interference from the neighbor building, I ran an antenna to the outside of the building and the noise got a lot worse.
I wonder if a grounded shield on the side of the antenna the interference is coming from would help.
Old 03-02-2016, 04:02 PM
Did you connect to a decent ground as well? Otherwise, results might be inclusive.
A better test is to take a good portable outside, and observe the interference level.
Old 03-02-2016, 04:22 PM
Installed a similar filter in another radio, and it works as well as my first radio. This is a Hitachi AM-FM K760H. Added an extra coil to this filter board for more filtering.
Old 03-02-2016, 06:10 PM
maxhifi's Avatar
maxhifi maxhifi is offline
does that radio have a power transformer ?
Old 03-02-2016, 06:40 PM
No, it's a hot chassis SS design. Originally, thus the noise would ride directly in, vs having to hop across the power transformer's winding to winding capacitance.
Old 03-02-2016, 09:24 PM
Titan1a Titan1a is offline
I believe the only definitive way to minimize noise is with a loop antenna. The loop uses the magnetic part of the radio wave and is highly directional. I use a ferrite loopstick antenna and it greatly helps. I plan on getting a much larger Wellbrook loop and another loopstick.
Rick (Sparks) Ethridge
Old 03-02-2016, 09:37 PM
I did take my GE Superadio outside and the noise seems to be coming from the building behind me.
This poor reception is in my workshop building. My AM reception at my residence is good in most rooms of the house.
Old 03-03-2016, 09:21 AM
dtvmcdonald's Avatar
I finally found two ways to get rid of interference from other apartments in my
building and the power line.
1) For LW, BCB and up to about WWV at 2.5 MHz, loop antennas.
2) For BCB to 30 MHz, an outside wire antenna, 25 feet long (noncritical) draped over
a tree from my balcony, and as counterpoise a good, solid connection to the
balcony's metal railing, which is large and not grounded. This is connected to radios
inside with top quality RG-6. However, the commercial F-connector attachment
points are an Achilles' heel as they are not soldered on.
#2 has the problem that the antenna does not match the coax except at
a couple of frequencies, ruining reception strength. This was fixed by adding
a 2-transistor emitter follower with built-in anti-FM radio filter, right at the
antenna-balcony junction. This has a 6kohm input impedance. Its powered by
a 9 volt battery (transistor radio batteries don't last long. I use 6 D cells.)
The results from this antenna are very good.
Please ... no comments about "you must ground the antenna".
THAT DOES NOT WORK! The noise returns. Its grounded through the
coax, and the wire is retracted when not in use.
Old 03-03-2016, 12:37 PM
DavGoodlin's Avatar
DavGoodlin DavGoodlin is online now
Motorola Minion
Originally Posted by Dave A View Post
Would this work to reduced lamp dimmer interference? This is outside of my wheelhouse of knowledge. This sounds like a nice little wall-wart sized module project.
The effects on the BCB from a standard rotary incandescent lamp dimmer, generating line harmonics from Triac and SCRs, should be reduced by this filter.
I used an integrated (grounded) line cord receptacle combo with M-derived filter from a CRT monitor. The 1937 Philco I put it in needed the chassis grounded anyway and it trapped almost all of the line hash, leaving the band nice and open at night.
With fluorescent lights using an SMPS as the electronic ballast , its more of an issue with HF, VHF and FM bands. Much of that interference is radiated from the lamps, not via power line. separation from and nullification with antenna placement helps.
The absolute worst offenders I found were the higher-wattage compact fluorescents operating on electronic ballasts (commercial twin and quad tube 18-42 watts) yet residential screw-in spiral types seem harmless.
The second worst offenders are the three and four-lamp electronic ballasts (2,3 and 4 foot T8 lamps) likely due to higher harmonic current drawn like the twin/quad tube compacts. Two lamp units, even with 8-foot tubes, are not too offensive.
I took great care in selecting "can" and "bowl" lighting for halls and parlors in retirement homes, thinking primarily of the residents that lived there. All the lighting supply houses and even ballast manufacturer reps were ignorant of this issue. I made sure they did when specifying.
I have found that the emission from rapid-start and trigger start magnetic fluorescent ballasts (older T12 lamps) is minimal and only a problem if the fixture is not properly grounded. cheers for old technology
-Dave G
Old 03-16-2016, 08:41 PM
Banned
I have a 13 Watt CFL Bulb in my lamp on my night stand in my bedroom and in the lamp in my old room at my parents house and I've noticed that those 13 watt (and larger) CFLs (which are electronically ballasted) send severe amounts of EMI interference to my alarm clock Radio next to my bed in my bedroom and to the boombox that's in my old room at my parents house on the FM Band specifically between 88.1 and 98.1 Mhz on the FM dial, I haven't tried the AM Band recently because I haven't had a need to listen to it recently although on my old transformered AM Radios from the 1930s-1950s the AM Band comes in flawlessly even with all of my lights having CFLs in them. Another thing I've noticed is that at my parents place they have 2 Electronically Ballasted 2 bulb T8 Style Florescent lights that replaced 2 2 bulb magnetic ballasted T8 Style florescent lights and anyways whenever the overhead lights are turned on in the basement of my parents house every radio in the house using the FM Band becomes unlistenable and hums like mad and cannot pick up any stations at all, especially on the lower half of the FM dial, so I think that these Electronically ballasted florescent lights whether they be overhead lights or CFLs are extremely noisey when it comes to interfering with radio signals when they're on and need to be banned from use or at the least better regulated and designed to meet FCC Regulations for EMI Interference (which currently as it sits the FCC doesn't regulate nor do they know about the electronic ballasts effects with EMI interference, which means that technically electronic ballasts as they sit right now with all of their EMI interference that they give off are illegal because they aren't regulated by the FCC for their EMI Interference (like TVs, radios and satellite and cable boxes are) and like I said the FCC isn't even aware that Electronic Ballasts give off large amounts of EMI Interference, so because of that these Lighting manufacturers were knowingly manufacturing these ballasts illegally knowing that they gave off large amounts of EMI Interference, and never even bothered to contact the FCC to get their ballasts properly certified or even to get the proper amount of EMI Interference levels from the FCC so that they can make their ballasts within proper and legal specifications concerning EMI Interference emissions.
What I think really needs to happen is to boycott these florescent light manufacturers by buying only Incandescent lights until these florescent lighting manufacturers can properly make their electronic ballasts within legal specifications or go back to making magnetic ballasts again, because its absolutely rediculous that I have to loose my ability to listen to my favorite stations just because these floresent lighting manufacturers are too lazy to make their light fixtures the right and legal way!
Sorry for my long rant but this is how I feel about this issue and I find it frustrating that nothing has been done to rectify this issue so far.
Old 03-21-2016, 10:40 AM
DavGoodlin's Avatar
Motorola Minion
The good news is that LED is steadily replacing the CFLs, to be know as the "new" dinosaurs.
Older lighting, like mercury, T12 fluorescent, high intensity discharge HID (metal halide and high pressure sodium) using magnetic ballasts are all over the place yet, but these do NOT make interference.
LED will claim them all once replacement parts are phased out of production.
I can only hope the CFLs die quickly and are retrofitted with LED >-:
-Dave G
Old 03-21-2016, 03:03 PM
But the switch to LED does not necessarily cure all RFI problems... some are very strong emitters, causing problems even to the top end of the FM band. Best to try a sample of a given bulb type first (with a good return policy) and test using the weakest stations that you normally listen to before buying more. I am about 90% converted to LED lights, and with careful selection, AM and FM distant stations still can be heard fairly well.
Old 03-21-2016, 06:32 PM
They are after all diodes and it'd be surprizing if there wuzzn't some switching noise.
Old 03-24-2016, 07:09 PM
The Soceity of Broadcast Engineers is presently urging the FCC to get more involved in cleaning up the RFI mess, read about it here:
http://www.arrl.org/news/sbe-urges-f...se-environment
