Old 11-05-2015, 10:34 AM
b&k tube tester model 606 problem
Here is the problem all of a sudden it wont read shorts/gas. The resistors seem to be ok and the what 2 capacitors and it wont indicate anything. The lamp is ok and even if you select the two same numbers like 7 and 7 the lamp should light and it doesn't. Any ideas on what's wrong? The tube inside is the only this I can think of but checked it on a different tester and it reads good emmisions but that's all I can say about the tube. Is there something I overlook. Thank
Old 11-05-2015, 11:33 AM
Gregb Gregb is offline
How did you determine that the bulb is good? Did you try it in another unit?
Gregb
Old 11-05-2015, 12:10 PM
Findm-Keepm's Avatar
Followin' the Rules...
If R-6 is misadjusted, it will shunt any voltage across the NE-51. It can be adjusted toward 0 ohms, and will negate the lamp in the circuit. If it hasn't been adjusted, look for any debris/tin whisker within the pot.
Do you get the momentary flash when switch C is rotated throught the positions? If not, check the .05uF cap - it discharges momentarily and will cause one element of the neon shorts lamp to flash when switch C is rotated.
Brian
USN RET 22YRS (Avionics/Cal)
Old 11-05-2015, 09:16 PM
It will not flash when c is rotated but it used to. The lamp is good. It only shows a momentary flash if you press the test button. This.05 is it on the meter? The electrolytic was replaced but not the cap on the meter. I only saw two caps inside.
Old 11-05-2015, 09:59 PM
One end of the .05 connects directly to the NE51 Shorts lamp. It's not the cap across the meter terminals - that is a damping capacitor for the meter.
Take a good look at the schematic and compare it to the wiring of the 606 and you'll find the cap easily.
Brian
Old 11-06-2015, 08:01 PM
I have no schematic but will look for the cap and replace it. Thank
Old 11-06-2015, 10:13 PM
The entire manual is available online for FREE at BAMA and other sites. Schematic and theory of operation are in the manual.
Brian
Old 11-07-2015, 06:13 PM
I have two books with tube numbers but no owners manual. Replaced the cap and it seems to be working...... i wasnt thinking of that cap because it is a disc. ......... Thanks guys.
