Old 10-18-2015, 09:17 PM
damen's Avatar
damen damen is offline
If they are both in the book, check to see if there is a tube that they both sub to. If that is the case the worst you'll have to deal with is mounting hardware differences.
That was a good call, they both sub for a 25VBEP22 so that makes me feel a little better to.
Old 10-18-2015, 09:25 PM
damen's Avatar
This is the tube in my 1971 Magnavox. I am curious if it is the original since it has the label that says all new picture tube. Could this be a warenty replacement tube maybe? Anyone know how the date code works on Magnavox tubes? This tube is not bad I was just thinking of having the 25vcx tube as an extra for this set.
Old 10-18-2015, 11:34 PM
A Magnavox guy once told me that the serial number of the original tube will match the serial number of the TV.
Old 10-31-2015, 08:08 PM
eberts eberts is offline
specs
The 25VCX is a high lead glass rated to operate at 30kv, it is a negative guard band black matrix phosphor screen.
The 25VCD is for 25 kv operation and does not contain higher lead glass. It has a standard aluminized phosphor screen with no black matrix.
