Old 10-07-2015, 08:59 PM
TUD1 TUD1 is offline
Acceptable repair?
I'm repairing an el cheapo RCA Victor AM/FM radio from the 60's and I wanted to see if my capactitor replacement idea is okay. It needs a 50MF and an 80 MF. I don't have any that high, so I connected a 47 and a 33 in parallel for the 80, and a 47 and a 10 in parallel for the 50.
Old 10-07-2015, 09:13 PM
rca2000's Avatar
rca2000 rca2000 is offline
It would be better to use a 100 UF and a 47 UF...but your idea will probably work ok.. These are likely just used for filtering...assume this is a hot AA-5 type radio--so a 160 volt cap will work ok.. If a cold chassis--better use 400 volt ones or so..
Old 10-07-2015, 09:32 PM
The old one was only for 200 volts, and I guess it worked okay. This is a 6 tube radio with a printed circuit board for a chassis. I just want to get it working good enough to sell at the next swap meat.
Old 10-07-2015, 09:35 PM
rca2000's Avatar
If it is a 200 volt cap--use a 200 volt or higher one...maybe 250 volt one.
Old 10-07-2015, 09:43 PM
Arcanine's Avatar
Arcanine Arcanine is offline
The old timers may toss a fit but it will work perfectly fine.
I did a repair much like this when I recapped an old 1946 Arvin radio recently. I had no 40uF caps at 150V on hand, only 22uF caps at 450V, so I just combine two to make 44uF at 450V, works perfectly.
Old 10-07-2015, 11:17 PM
No need for the 10 in parallel with the 47 (no harm in it either).....47 is close enough to 50 to work fine.
Old 10-07-2015, 11:48 PM
Well I did the repair, and the radio is dead to the world. Completely silent. Oh well. If I can get $10 for it, I'll be doing good.
Old 10-08-2015, 10:56 AM
Old timers have been doing it, long before we started!
The best hackery, was when the old timers used to carve away, the old-fashioned dog-bone resistors to get the resistance they needed.
Old 10-08-2015, 11:04 AM
Do the tubes light?
If so, check the B+. Does the set use a silicon or selenium rectifier? If no B+, it could the surge resistor, before or after the rectifier.
BTW, did the set hum, before the 'lytics were replaced.
Old 10-12-2015, 05:46 PM
Sr.Radtastic's Avatar
Sr.Radtastic Sr.Radtastic is offline
May you please post a photo of the radio. I have several 60s RCA Victor radios and my first radio repair ever was on a '62 RCA clock radio with faulty capacitors. Hopefully I can help you and it may turn out that you and I have the same radio!
Sent from my iPad using Tapatalk
Old 10-18-2015, 12:01 AM
Tubejunke's Avatar
This is what I would say and want to back up because the "rule" is to never go lower than the rated capacitance (or voltage), but if you are real close like that, then I say go for it.
Old 10-18-2015, 11:36 PM
ggregg's Avatar
ggregg ggregg is offline
Many electrolytics have a 20% tolerance anyway so it's possible to have 50 that's actually a 40. 47 will be fine although a little higher surely won't hurt either.
Old 10-19-2015, 12:08 AM
rca2000's Avatar
Cap values have changed over the last few decades...a 50 UF is no longer common. 47UF has replaced it.
Old 10-19-2015, 10:48 AM
I measure the caps before I use them to restuff my can 'lytics, with my Chinese ESR meter. A few of my 47's read 46.5.
Old 10-19-2015, 11:13 AM
Findm-Keepm's Avatar
Followin' the Rules...
Oh, do tell, what brand of caps are those 47's?
Brian
USN RET 22YRS (Avionics/Cal)
