Old 08-10-2015, 06:54 PM
TUD1 TUD1 is offline
My new Philco 40-180
I scored on the World's Longest Yard Sale the other day! I got this gem for only $30. The veneer is in excellent shape, the only thing I did was polish it with GOJO. It plays and sounds quite good considering I just got it home. I still have to fix the dial string, though.
Old 08-10-2015, 09:44 PM
I has the metal dial bezel. The push buttons were the red crumbly plastic ones. The radio's nice enough to buy new repro buttons.
The set must've looked real sharp, when the push buttons were lit up by the dial light. They were somewhat translucent.
Old 08-11-2015, 09:11 AM
DavGoodlin's Avatar
Motorola Minion
Ya did good on this one and got lucky too Compared to 41-42 Philco sets, only ONE condenser block is used in this chassis which should make recapping easy.
Just my 2c but the 84 rectifier tube should be replaced by two 600V rectifier diodes and a power resistor. Cheap insureance for your transformer.
I had to buy those wine-colored pushbuttons and an audio output transformer for a 40-195 I restored. Antique Radio Supply has those buttons and they do look nice lit up!.
-Dave G
Old 08-11-2015, 10:33 AM
There is a new generation 84, that looks like a 6X5GT, but with the 5 pin base. They also made a 41, the same way.
I worked on one that looked like the transformer had been replaced. The previous tech changed the socket to use a 7Y4, instead.
The older couple, that owned it, bought it brand new and mentioned how much they paid for it and the store name.
Old 08-11-2015, 12:30 PM
DavGoodlin's Avatar
Motorola Minion
The 1975 RCA tube book RC-30 equates tubes with same characteristics but differ in bases-pinouts 41=6K6, 42=6F6.
I think the odd numbered 1232 RF amp is same as a 7G7
-Dave G
Old 08-11-2015, 01:30 PM
I have a couple of Zenith branded 1232's. One has both numbers, 7G7/1232.
Old 08-11-2015, 07:43 PM
The rectifier installed in this radio is an 84/6Z4. I thought the only tube that should be replaced is the 6X5 in other radios. And I've also heard speculation that the later 6X5GT's are fine. I asked about this on the Philco Phorum, but nobody seems to care to reply.
Old 08-11-2015, 08:17 PM
Gregb Gregb is offline
Really nice score on that one, I have always liked that cabinet design. I was not aware of any issues with the 84 rectifier tube, I have a couple radios that use that tube. I don't play them very often so will leave them alone but be worth keep an eye on.
Gregb
Old 08-11-2015, 10:39 PM
Thanks, all of you. You folks seem to be more considerate than those of the Philco Phorum, I appreciate that. This Saturday, I'm going to take this radio to the AHRS and restring the dial cord and clean the controls. Possibly replace the electrolytics, if they haven't been already.
