Old 08-10-2015, 07:57 AM
Magnavox300's Avatar
Magnavox300 Magnavox300 is offline
..better in black & white
Just to be clear - C1 is the cathode bypass cap. It connects to the cathode on the vertical output tube.
The cap that went bad was C2-B which combined with C4 filters ripple out of the boost voltage.
Okay, so then I did replace the cathode bypass cap username1 originally suggested...
I did see it was the only cap coming off the vertical tube, and even though it tested well, I did replace it... thats when I noticed the burnt mark on the C2-B cap since it was right underneath C1.
Old 08-11-2015, 03:01 AM
Tubejunke's Avatar
Delete
