Old 07-09-2015, 11:19 PM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
And here is the trace side:
Sony Trinitron Fan
Old 07-09-2015, 11:27 PM
rca2000's Avatar
rca2000 rca2000 is offline
Ok...on the side of those 15K resistors on the CRT board--the side AWAY from the three video out transistors....see what the voltage is to ground. It HAS to be at least 170 or so. if low or "jumping around"...SOMEWHERE...something on the line is OPEN.
I see what looks like a small choke on the line from the chassis..looks like L 501. these like to OPEN and kill the 200 volt supply OHM this...it should shoe under 50 ohms...if HIGH it is OPEN.
Old 07-10-2015, 12:10 AM
Oh, those are chokes? I was wondering what they were! The device next to the single electro cap is marked BC501.
Where should I ground the other meter probe?
Sony Trinitron Fan
Old 07-10-2015, 01:37 AM
rca2000's Avatar
To cold ground...likely the CRT ground strap.
As for the choke...measure across it like the resistor. It should NOT show open. The voltage should be pretty much the same on EACH side of it...according to ground.
Old 07-10-2015, 08:24 AM
Findm-Keepm's Avatar
Followin' the Rules...
Hope this helps.
Brian
USN RET 22YRS (Avionics/Cal)
Old 07-22-2015, 10:37 PM
Originally Posted by Findm-Keepm View Post
Hope this helps.
That helps considerably, thank you! I have sort of 'back burnered' this TV until I get through some other projects, while my friend uses my loaner Sylvania.
Sony Trinitron Fan
Old 07-24-2015, 12:47 AM
Dude111 Dude111 is offline
Analogue is Awesome
Good luck getting her fixed and working ok
