Old 11-22-2014, 02:09 PM
Looks like the green are your vertical and the red (faded to tan*) are your horizontal.
I'd try it with the caps first and snip them if they are causing any issues. On yoke swaps I usually do the first power up with clip leads so I can quick turn it off and swap them if I got a winding connected backwards.
*I recently repaired a 50's amp for a guy and one of the tan wires had a stripe of black letters running along it that consisted of the word RED repeated over and over...I had my self a good laugh when I noticed it.
Old 11-22-2014, 03:46 PM
Tom Albrecht's Avatar
Probably best to follow the wires to the actual coils to identify H vs V. The H coils consist of two closed loops, one above and one below the neck. The V coils are on the sides. If the picture ends up upside down or left-right mirrored, all you have to do is swap the leads of the particular deflection coil that is producing the problem.
(Edit: I didn't see Tom C's post before I replied - there is some duplication in our responses.)
Old 11-22-2014, 06:12 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
The good news: Looks like I got it right!
The bad news: HV faded out. Stops at the top of the 1B3. Next is a doorknob cap and a resistor, so one of those is shot.
Not giving up yet
Old 11-22-2014, 07:38 PM
Is the 1B3 filament glowing?
Old 11-22-2014, 08:37 PM
Kamakiri's Avatar
I'm pretty certain it was, actually.
Old 11-23-2014, 12:12 PM
i would try the doorknob or doorknobs if it has more then one , that is if your not too buried in the snow, and you do now have a fly tester , simple to use , remove these tubes , the horz out , the hv rect , the damper , one wire goes to the plate cap wire of the horz out and the other to the plate cap wire of the hv rect , before connecting the wires you turn it on , set it to shorts , adjust the needle to the iron core line on the meter , hook wires up to the plate cap wires without touching and you will get your results , the fly will probably sing too.
Old 11-23-2014, 04:41 PM
Kamakiri's Avatar
Flyback was buzzing ever so slightly
Passed the continuity test easy, but the shorts test is not looking so good
And I did disconnect half of the width coil as per the tester instructions.
Old 11-23-2014, 04:45 PM
Kinda crispy looking too isn't it?
Old 11-24-2014, 09:23 AM
Kamakiri's Avatar
Yeah, kinda
Why is it that sets I fix for other people are easy jobs, and MINE are SUCH a pain in the ass?
Old 11-24-2014, 06:12 PM
At least you don't gotta tell folks that X$ of work and caps into it you found some blown part that could be nearly impossible to find...I dread that possibility; which is why I rarely work on other peoples stuff.
Old 11-24-2014, 08:10 PM
Kamakiri's Avatar
And along those lines, neither Stancor nor Thordarson list a flyback for this set.
Welp, looks like I'm gonna pull the picture tube and put it back in the Emerson from which I stole it, and restore that one. I'll stick this one aside until a parts set happens to become available.
Old 11-25-2014, 12:18 AM
Tim's Avatar
Tim Tim is offline
Merit lists HVO-90 as the replacement. Possibly one will turn up.
Tim
Old 11-25-2014, 08:16 PM
Penthode's Avatar
Penthode Penthode is offline
I haven't seen anyone ask this. I generally test the transformer in service by removing the 1b3 cap and see if I can draw an arc. I would take a pointed screwdriver and connect one end of a clip lead to the screwdriver and the other end to ground. If I can pull a 1/2" to 1" arc, I am satisfied the flyback transformer is okay.
I saved myself looking for a transformer on my old RCA 8TC271. The doorknob capacitor had shorted. I did the same later on my Zenith color TV to find the arc was healthy and the rectifier tube was bad. This was only after I had moved and acquired the spare transformer!
Old 11-25-2014, 09:34 PM
Wow. Are you serious about connecting it to ground?
The only way i've ever done it or seen it done is to draw an "air arc" with an ungrounded but well insulated screwdriver.
The air arc is just about as long anyway since it's RF. And it doesn't risk overloading the xfmr as a straight-to-ground current path might.
Old 11-25-2014, 10:19 PM
Tim
that reading isn't the worst , if you lay the fly tester on its back does it show a different reading ? if the meter went all the way down it would be bad , i've seen good flys read what you are getting , i thought i had a bad fly once because of a reading like that and went through the headache of replacing the fly and it had the same reading , the problem was the doorknob
mike
