Old 11-08-2014, 12:11 PM
tvdude1 tvdude1 is offline
Zenith clover leaf
This might be a slim chance but does someone have a zenith part number 43-473 they could sell me please?
Old 11-08-2014, 12:42 PM
If you're referring to the convergence yoke cloverleaf to replace a broken one, there used to be an aftermarket item made expressly for this. It consisted of a bungee band sized to fit around the outside perimeter of the housing, holding the whole thing snugly in place.
No doubt a similar item could be rigged if a replacement cloverleaf is not available.
Old 11-08-2014, 05:35 PM
it just crumbles. I found the part number in the Sams folder. too bad i missed my chance. Stella tv had some but I did not know the number then. Sucks for me. Hope someone helps me.
Old 11-08-2014, 10:48 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I was wondering if the cloverleaf from an RCA which uses the same yoke and CRT would work. The Zenith ones do suffer from brittle plastic. The RCA ones seem to be a bit less fragile. I would expect them to be relatively interchangeable. Has anyone tried this? I hate early plastic. It just does not hold up well over time.
Old 11-10-2014, 09:41 AM
Found some from Moyer Electronics. Good to go was also cheap.
