Old 10-08-2014, 08:20 AM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Wow, that's great!
Thanks!
Old 03-02-2015, 07:31 PM
Just a quick followup on this set ; I never had to do the convergence on it. After I "clean and balanced" it, all I did was to redo grayscale, and all the gun went back into almost perfect convergence...
I suppose that the clean and balance procedure ironicly "debalanced" the 3 guns and that might have resulted in misconvergence (great knowers here might want to correct me on that one of course )
Now another question : the image on the tv is pulling ever so slightly on the right, thus cutting a bit of the picture. I went around to find an horizontal centering pot, but found none. Is it possible that my TV lacks the needed ajustment to do so?
Thanks!
Old 03-03-2015, 08:55 AM
Thanks!
First, all sets are built to overscan just a little. Also these days you
gotta watch what you are feeding them.
If you got one put a cross hatch pattern up & be sure the lines are straight.
If not you have a pincushion (pin) problem.
Look for any control or jumper marked horz size, width, or lin.
If it has a horz hold move that a little.
Power supply can do it but usually causes random shut-down & other
symptoms.
If you can check the current draw. Should be about .75 amps with
a normal picture.
If there is a true problem its probably a 'lytic going bad.
Old 03-03-2015, 04:47 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I've noticed late 80s/early 90s RCA-built sets, i.e. my 1989 GE, overscan quite a bit if no signal is present. The channel display goes almost completely off the screen.
Old 03-03-2015, 04:59 PM
Found a jumper (horizontal cent.)that was marked : N or R , the selector was on the R pin...so I tried the N one...and that solved the problem!
Thank Zeno!
Old 03-03-2015, 05:06 PM
Did not notice if the overscan was worst when there was no signal, but it was definitly bothersome on DVD/VHS signal. Glad to be rid of it!
