Old 09-03-2014, 10:31 PM
rodmonster's Avatar
rodmonster rodmonster is offline
Woodbridge, Virginia
Help with Phono - RCA Victor 18t AM Radio
I bought a 1940 RCA Victor AM / Shortwave Radio today. Model 18t.
http://www.radiomuseum.org/r/rca_18t.html
Pics are below.
Ok - Im cleaning it up and it runs pretty well. Decent sound.. Stations work.. etc..
BUT...
For the life of me i can figure out how to use the Television/Phonograph audio jack. There is no button on the front to indicate its use. The jack on the back looks like a standard RCA - but in reading up online i think it may have used a quarter inch RCA jack instead. I have tried a standard RCA and a quarter inch adaptor. Nothing happens.
I have put it in every setting on the front - and it still just plays the radio...
Ideas? I would love to be able to plug in an FM radio or Phonograph to it...
Please Advise...
"Bring back the 80s"
Old 09-03-2014, 10:41 PM
Pics are below.
BUT...
Please Advise...
The tone selector switch should have a phono position. second control from the left.
Old 09-03-2014, 10:44 PM
rodmonster's Avatar
tried - but
I tried that and it seems to just play the radio at a different tone.. with treble or bass.
Seems to do the same for AM - or the Shortwave.
Old 09-03-2014, 11:05 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Without question it is the tone switch. Check you may want to take it apart and clean the switch and in the process figure it out
http://www.nostalgiaair.org/PagesByM...1/M0014801.pdf
Old 09-03-2014, 11:07 PM
rodmonster's Avatar
ok
OK..
So i wonder which mode it has to be in on the right then..
A B C or PB
I will play with it some more...
Old 09-08-2014, 08:25 AM
rodmonster's Avatar
Working!
Ok - update.
I did two things.
1. I cleaned out the RCA jack a bit in the back.
2. I found an OLD RCA jack from the 60s... momo analog... and sure enough - that worked.
I did need to use the tone dial - and the radio did keep coming through - until I got the RCA cable in to work - then it over road the radio.
Thanks for the help yall!
Old 09-08-2014, 12:47 PM
Ok - update.
I did two things.
I just wonder if RCA changed the phono input in the later runs.
The Riders shows a phono position on the tone switch.
Old 09-08-2014, 12:52 PM
I had an older RCA tube set that IIRC used the longer center pin RCA connecter to disconnect the radio section...
Old 09-08-2014, 06:27 PM
That's what I was referring to, when I mentioned that there might be a change in production.
I had an RCA that had a closed circuit phono jack, that when a phono plug was inserted, the radio was silenced and the input was live.
The radio, being referred to, was a great performing set.
Eight tube, transformer powered, with push-pull output and a tuned RF stage.
What more could you ask for?
