Old 06-22-2014, 03:12 PM
Console User Console User is offline
Picture Tubes and Rebuilding
Is there anywhere to get rebuilt picture tubes anymore? Are they still going to someday rebuild the picture tubes in Ohio with the equipement that they acquired from Hawkeye in Iowa?
Old 06-22-2014, 09:17 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I think they only plan to rebuild early B&W and roundie color CRTs.
Old 06-23-2014, 07:12 PM
There is no one currently rebuilding picture tubes. You can read more about the ETF project by following these links
http://www.earlytelevision.org/crt_project.html
http://www.videokarma.org/forumdisplay.php?f=185
Old 06-23-2014, 07:32 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Wow this is more than I ever imagined would be possible...I really hope this will work.
Old 06-23-2014, 09:41 PM
Jon A.'s Avatar
Yeah, but even if they do make a go of it, would it be of any benefit to those of us who are into the "newer" stuff?
Old 06-24-2014, 10:00 AM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
Well on "newer" stuff you're less likely to have to re-phosphor the face, so in theory if there's a compatible gun/stem available it could be swapped in with some level of success. Also of benefit to gassy tube owners (metal cones take a number.) with potential ability to re-evacuate the bulb if the leak can be located with a mass-spec probe and sealed with frit or other vacuuseal type stuff.
Old 06-24-2014, 12:59 PM
Keep in mind that color tubes can't be rephosphored (I doubt anyone even did that back in the day). The complexity of dismantling the screen from the bell (without damaging the shadow mask), reapplying a grid of VERY tiny and precise phosphor dots, realigning/attaching the shadow mask and reassembling the whole thing would be prohibitive.
Old 06-25-2014, 11:49 PM
Jon A.'s Avatar
That being said, I reckon it's a bit too late for this one:
Old 06-26-2014, 02:46 AM
David Roper's Avatar
console lover
Ooh, that's pretty.
tvontheporch.com
Old 06-26-2014, 08:58 PM
I bet that'll buff right out.
Old 06-26-2014, 10:27 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Couple taps with a sledgehammer and i bet you wont be able to notice it....
SR
Old 06-27-2014, 04:33 PM
You are right, no-one could re-phosphor color tubes. Each tube/yoke type needed a matching light-house optics to expose the photo resist for depositing the dots. Plus, I seem to recall something about the negative guard band tubes being exposed and phosphored while the mask still had small holes, which were later enlarged before final assembly. Anybody know about that for sure, or am I dreaming?
Old 06-27-2014, 04:38 PM
The thought occurs to me that today you could add programmable dynamic purity coils to a CRT and adjust the purity for whatever mismatch occurred in the re-phosphoring. This of course would be more complex than the whole circuit of the original set, but it seems conceivable.
