Old 12-03-2013, 07:32 PM
Lloyd's AM/FM/SW Japanese tube radio
Many people associate the Lloyd's brand with cheap solid state stereos and radios from the '70's and '80's; but, they did import some cheap tube radios during the '60's.
This radio looks to be from the early-to-mid '60's and is very long. The tubes are Toshiba-branded; but, I don't know if they actually built this radio. The radio has reception; but, the volume is very weak and distorted. So, it probably has leaky coupling capacitors in the audio circuit. Those old grey Japanese paper-in-oil capacitors are usually very leaky by now.
Old 12-03-2013, 07:54 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
Nice radio. I've seen this model around before. These used to turn up fairly frequently at swap meets and such. I bet after new capacitors are installed, and the unit checked out, it will play quite well.
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 12-04-2013, 02:23 AM
All those lights make me think FM stereo, but the chassis makes me think dual speaker mono.
Old 12-04-2013, 12:14 PM
It's not stereo. Those lights simply indicate which band you are on.
Old 12-04-2013, 12:36 PM
I've got its "Double-1st cousin" dual speaker, AM & 2 SW bands. Pretty decent little desk radio for the Ships' Radio Room for when I don't wanna fire up one of the big "Bacon fryers"...Gets WTAM 1100 in Cleveland exceptionally well, sometimes listen to "Ground Zero" & "Coast to Coast AM" before hittin' the hay... Can't remember the brand on mine, it may be a Lloyd's, too dam lazy to go look..
Old 12-04-2013, 03:46 PM
It doesn't claim "stereo", does it? I don't see enough tubes to provide a stereo decoder. I have an AM/FM radio that claims "balanced stereo speakers" even though it's just a pair of speakers fed by a mono signal.
Old 12-04-2013, 10:14 PM
No, it's a mono job with the speakers wired together. However, I have a similar JVC/Delmonico radio from the same time period that is a true FM stereo radio. I also have a similar Commodore "Stereo Matic Sound" radio that is simply a mono radio with the speakers wired together.
Old 12-05-2013, 08:47 AM
DavGoodlin's Avatar
Motorola Minion
The speakers in that Lloyd's are better than most of those 60's Japanese sets, plus an earphone jack and shortwave as a bonusand the tubes are Toshiba, but may be not indicative of the original manufacturer.
I had the same Commodore "stereo-matic" also, given by my 4th grade teacher as a bribe to stop "doodling on my tablet" and listen up. The tubes were labeled "Ten" which is Fujitsu. It had four 4 inch round speakers, sounding decent but the FM selectivity was awful.
-Dave G
Old 12-05-2013, 11:33 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Originally Posted by DavGoodlin View Post
I had the same Commodore "stereo-matic" also, given by my 4th grade teacher as a bribe to stop "drooling on my tablet".
Slobbered a lot did ya?
Old 12-05-2013, 01:03 PM
Be careful you don't slobber on the radio, it's likely a hot chassis
Old 12-05-2013, 02:57 PM
Robb's Avatar
Robb Robb is offline
Nice radio !
flickr
Old 12-05-2013, 07:34 PM
DavGoodlin's Avatar
Motorola Minion
Drooling commenced the following year....
-Dave G
