Old 09-13-2013, 12:50 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Is there a such thing as a reliable tube color TV?
Yanno, between nearly impossible to solve convergence issues, replacing 6GH8s about every other hour, horrible purity, bad picture tubes, yokes that fall apart due to brittling from heat....not to mention the tedious restoration process and the de-cataracting of picture tubes, are there any tube color sets that can be made to be reliable in 2013?
Reliable, not as in when they were new, but well built enough to be made to be reliable today.....
Old 09-13-2013, 01:24 PM
get an early 70's Zenith.
Old 09-13-2013, 01:28 PM
zenith sets are prob the most reliable IMHO. they often work with no restoration needed what so ever. I have several both roundies and rectangles that are very reliable. They also have CRTs that have bonded screens that while may turn a light green around the edge, are still watchable without removing the lens.
oh one more thing, if you really want to use it a lot, putting a fan in it to help keep cool may help with long term relialblity. I added a fan just for this reason to my CTC-5.
Old 09-13-2013, 01:39 PM
Kamakiri's Avatar
I kind of figured that, so I bought a Zenith roundie recently in working condition, semi-restored. Worked for about two minutes when I got it home, picture started to shrink from the bottom, and I started to smell something. Shut it down. What a let down. I'll get to that once I get the customer work done.
RCAs, though, I have zero luck with.
I guess you can call this thread a "rant". Your support and commiseration is appreciated
Old 09-13-2013, 01:51 PM
6GH8cowboy 6GH8cowboy is offline
In my days in the biz, Zeniths seemed to be fairly reliable but the pix didn't always offer a good color rendition of facial tones. RCA's could do very well but I think RCA was making up for lost time and money to recoup for the cost of color development that ran soooo over what was expected. Quality in production could have been better. Dumonts and Admirals had spectacular color but were less tollerant of differences in cameras and stations back then.
Today we fix, tweak, craft, rewire, scrounge, and sometimes talk to sets that were never reasonably expected to last 50 plus years.
We are Jug Heads! It's what we do.
Old 09-13-2013, 01:52 PM
well it will prob be something simple.
a few things I always do, pull the horz and vert out, do a slow power up while monitoring the AC line currrent (metered variac) and the B+ and temp of the filter caps.
I theory is this will give a cap time to reform (if its going to reform) and will also quickly let you know if there are any shorts in the B+.
Pulling the horz and vert is just done as a preventive measure in case the low voltage prevents osc and bias issues on the tube.
Typically I will let this process go on for several hours starting at about 10vac and working up to about 80vac, as long as the B+ seems ok and nothing starts to heat up.
My guess on yours is a shorted filter cap followed by a smoked resistor in the filter network.
I did have a zenith with a shorted disk cap but that was an easy fix and the only thing that was wrong with it. I did not even pull the chassis, just replaced it with the service saver chassis cover removed.
Good luck with your zenith
Old 09-13-2013, 01:55 PM
Kamakiri's Avatar
Incidentally, having attempted to watch both a CTC-25 and a CTC-36 on a regular basis, I now understand your username.
I might change MINE to 5GH8cowboy
Old 09-13-2013, 02:12 PM
truetone36's Avatar
electronics packrat
As a CTC-25 owner myself, I can relate to this.
Old 09-13-2013, 02:29 PM
Kamakiri's Avatar
I lost all color on my CTC-25, had a perfect black and white picture. Come to find out that two 6GH8s are SHORTED, replaced them, and now I have a purple band at the top, a green band at the bottom, and white in the center. Screen looks like a "Mystery Mix" Now & Later candy.
Yay.
Old 09-13-2013, 02:34 PM
I wonder if using 6U8's or 6EA8's would increase the reliability of sets that have all those 6GH8's?
Old 09-13-2013, 04:30 PM
holmesuser01's Avatar
I've tried them. It's got to be the 6GH8's.
DONT use the International/Lindal brand. Some runs of the RCA 6GH8's were better than others. I've had issues with GE 6GH8's in the past.
Side note: I replaced the 6EA8 in my CTC-10 tuner with a 6GH8. It worked good enough to leave it in. That was years ago.
Old 09-13-2013, 04:41 PM
egrand
Guest
Posts: n/a
On the car forums a lot of guys have a saying, "if you never had to fix it, it wouldn't be as much of a hobby."
Old 09-13-2013, 05:16 PM
reeferman's Avatar
After reading your "rant" I said to myself...he has an RCA.
IMHO the most reliable set belongs to someone else because I don't have to touch it.
And when it does break, oh well and good luck.
Have fun.
Phil
Old 09-13-2013, 05:41 PM
kvflyer kvflyer is offline
Didn't RCA use Sylvania manufactured (labeled RCA of course) 6GH8 tubes in their sets later on because of the reliability?
Old 09-13-2013, 06:08 PM
Fairly sure they did.
