Old 09-01-2013, 03:17 PM
Amazing how much damage one bad cap can do
I recently a posting on craigslist fro a free 1953 Admiral TV chassis just a few miles form home so I went to check it out. It turned out to be a 30B1 from 1948/49 with a replacement under warranty CRT from 1956. his parent bought the set new and he aid ti was working into the 90s when a transformer blew.
Unfortunately, he kept the nice blonde cabinet it came from to install a flatscreen inside. I figured if I get it running, I can offer it back to him or maybe put into one of my unrestored sets.
Ouch!
They stuck with Admiral branded tubes as the logo changed over the years.
Big gobs of wax under the power transformers seemed to confirm the previous owners prognosis but I want to find out for sure.
I also noticed a fried power resistor and another that was open. I decided to replace them and try a controlled power up.
No luck - the power switch is fried. I jumpered it and tried again. At about 80 VAC the replacement resistor was getting quite hot so I turned it off and did more hunting.
Eventually, I found another charred resistor in series with a 0.1mfd bumblebee cap. I measured the cap and it's a dead short!
It's also split open. So that one cap took out several resistors and the power switch
Ah, that's better
It still needs more work but has a pretty good picture already.
Old 09-01-2013, 04:45 PM
ISawItOnTV's Avatar
ISawItOnTV ISawItOnTV is offline
You sure know your stuff on these things. I've been pushing my internet bandwidth watching your Predicta "Holiday" restoration vids on Y-tube (I'm getting ready to replace some components on a Holiday chassis).
When I was young we had an old '50s Admiral ('52-'55?) that lasted until around 1969. It would be great to see the one you're working on get re-installed back in its original cabinet.
"I know it's true, oh so true, 'cause I saw it on TV"—John Fogerty
Old 09-01-2013, 05:02 PM
I hope to finish off the Holiday cabinet restoration very soon. I have my refinishing supplies out and am working on several cabinets before the weather starts turning cooler.
This chassis came from a 30B16 set that looked like this only with a blonde finish.
If he doesn't want it back, I think I'll put it into my similar 30A16.
Here's a look at the repaired speaker. I was able to glue the original cone back together except for one missing section that I patched with a coffee filter.
Old 09-01-2013, 05:32 PM
In spite of the cap incident, it's amazing how reliable those Admirals are while still utilizing so many original components after all these years. Possibly most of the caps are still good because that family kept using the set regularly up until if failed in the 90's. Pretty amazing. Very nice job gluing that speaker cone.
Old 09-01-2013, 07:43 PM
Very nice find, and it is good to hear that the transformers are not bad after all.
That CRT is from only a few blocks away from the rebuilder my employer used to use in the early 1980s, which was also on 47th Street in Chicago.
Old 09-01-2013, 09:18 PM
decojoe67's Avatar
Nice job Bob! I agree, those Admirals are very cool with their "chunky" looking cabinets. The next best thing to the bakelite version! One day I will find a good one of those!
Old 09-02-2013, 10:32 AM
Admiral must've had a factory service agency like RCA service company.
The original owner always had the set serviced by them.
Admiral had their own distribution and parts division. They didn't use privately owned distributors like the other major manufacturers did.
Magnavox and Curtis Mathis did as well. No middle-man, meant more profit for the dealer and the manufacturer.
Old 09-02-2013, 11:22 AM
kvflyer kvflyer is offline
A little late Bob, but from me too, "Nice Job!". Good to see that vintage set working. The 26R12 that I bought several years ago was working too. But it got the same things done that you do, caps, caps and more caps. All of the major components were good except the CRT. But I got an NOS one for it.
Cheers!
Old 09-02-2013, 12:33 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
We need a wider angle shot of that room
So it worked, with all of the other old caps still in place. Interesting.
Old 09-02-2013, 12:48 PM
truetone36's Avatar
electronics packrat
Sometimes those old Admirals will surprise you. I have a Model CH21UH33 from '59 that's still working perfectly on all its original components except for one tube which needed to be replaced when I got it. This set also saw regular use by the original owners until shortly before I got it though, so the fact it didn't sit unused for a long period of time is a factor, I'm sure.
Old 09-02-2013, 02:11 PM
That photo was taken a few years ago and sets are now scattered around all over. I really need a place with at least twice the sq footage
I'd guess about half of the original paper caps had been replaced in the past. So they're old, but not quite original. All the electrolytics were though.
I had some height an linearity issues that were solved by replacing the electrolytic cathode bypass cap.
The sound is still really weak. Possibly due to leaky mica caps inside the IF cans or bad electros in the audio amp.
Old 09-03-2013, 12:04 PM
i had an admiral 12" bakelite console , i think it was chassis 20x1 , it ran on the original electrolytics and almost ran on wax paper caps , person i sold it to i told him to try to run it atleast once a month for an hour to keep the electrolytics ok , don't know if he followed my advice , i should have done the electrolytics to be sure but that was back in the days when i'd only replace electrolytics that were bad , now i don't bother i just do them all to save future headaches , i may have had one that i didn't do them all and faced a problem , i know a friend got one that was restored a 9-t-246 that had a vertical issue , while running it testing voltages the picture started to go darker and darker till it went black and i scratched my head and wondered what happened , i checked the cans and one was hot , that was the cause , this set was used a lot about 10 years previous but sat unused for a long time , perhaps the one who restored it reformed the electros or they were good enough when restored but that one went sour after siting for a long period of time.
mike
Old 09-13-2013, 04:46 PM
I ended up doing a full recap and alignment on the set. Bandwidth is great ( > 4.0 MHz) and the linearity is pretty good.
One nagging issue is "waviness" in the picture. I cranked up the contrast to really illustrate the problem. I'm thinking there may be some horizontal ringing working it's way into the video ?
Old 09-13-2013, 05:40 PM
Wouldn't that be closer to vertical ringing? Looks a lot like 60hz modulating the horizontal oscillator.
Old 09-13-2013, 05:49 PM
Well the picture is in sync so I'm thinking that it's something leaking into the video.
Just checked the service info and it says vertical lines or "wrinkles" on the left side can be caused by spurious oscillations in the HOT, yoke or horizontal drive settings. I guess I'll start there.
