Old 05-04-2013, 09:39 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Bumble bee value?
Working on the formerly live-mouse-infested Magnavox, and there's only one bumblebee in it. Just so I don't screw this up , can anyone help me out with the value of this cap? TIA
Old 05-04-2013, 10:07 AM
snelson903 snelson903 is offline
looks like .047 but im unsure of the color of the 4th band is blue or gray, if you have 600 v i would use it depending on what circuit its in.
Old 05-04-2013, 10:22 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
.047 @ 400v
Old 05-04-2013, 10:29 AM
twbranch twbranch is offline
Man it must be early. I though you meant cash value! Geez coffee please!
Old 05-04-2013, 11:39 AM
N2IXK's Avatar
Technohippie
The ones with cash value are .022 @ 400V. Here's a pair of used ones for $75:
http://www.ebay.com/itm/2-Sprague-Bu...item27d1b059f0
The vintage guitar guys are giving the audiophools a run for their money in the gullibility department...
Old 05-04-2013, 12:50 PM
isnt that something ,dont people checkout anything, iv seen this before with wax paper too.
Old 05-04-2013, 07:33 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
I have a modern Mallory .047uF ~ 600V, Tim...you want it?
Old 05-05-2013, 05:58 AM
Kamakiri's Avatar
I actually stock plenty of the .047 @ 630v. I buy em in bulk
Old 05-05-2013, 08:15 AM
Kamakiri's Avatar
Two more of these, guys, if you would. These are on the Zenith Custom 23 Super H Chassis. I just don't trust my eyes, and I don't have a schematic handy
Old 05-05-2013, 03:32 PM
N2IXK's Avatar
Technohippie
First Pic--0.1uF @ 600V
Second Pic--0.1uF @ 200V
Old 05-08-2013, 02:02 AM
I like to use a conversion chart such as this: http://antiqueradio.org/art/recap13.jpg
I have a better one printed out, but can't remember where I found it on the net.
If you can read resistor color code, the capacitance is the resistor color code of those 'K' numbers on modern yellow replacements. For example a bumble bee with the first three bands YEL PUR ORG decodes to 473 which can be replaced by a modern cap with value of 473K(this is 47*10^3 thousand pico farads or .047uF)
Old 05-21-2013, 08:24 PM
Kamakiri's Avatar
Still a bit confusing for me. How do you get the voltage rating?
One more, gentlemen, if you don't mind
Old 05-21-2013, 09:42 PM
A little hard to make that one out.
If it's Brown, Black, Yellow it would be .1, the Blue stripe at the end would make it 600 volts.
The last stripe is the voltage and it's the same color code, Brown=100v, red=200v, yellow=400v, Blue=600v.
Not sure what that 4th band is, possibly tolerance?
Old 05-21-2013, 09:46 PM
Here's a link to a chart for BB Caps. 4th band is tolerance, Black is 20%, probably don't have to worry tolerance unless it's a green stripe, that's 5%, white is 10% and most modern caps are probably going to be within that.
http://www.pickguardian.com/pickguar...ee%20Chart.pdf
Old 05-22-2013, 07:15 PM
I agree with 0.1uF/600v for that last one.
