#31
The visible area checks in at a fraction under 18". And does anyone have Sams 838-3 they could part with? If not I will hit Kutztown. See you there.
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. |
#32
Diesel,
That may be where I remember this set. The ex's grandparents may have had one of these under one of the badges. The set would have been only 5 years old at the time. Her other grandparents had a Philco barberpole. Where is the Wayback machine?
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. Last edited by Dave A; 04-12-2013 at 09:16 PM. |
#33
Nice looking Panasonic! Cool & compact looking cabinet design, room for cooling air around most of the tubes! I will check tomorrow afternoon to see if I have the Sams, 838-3.
#34
I wouldn't be surprised to learn that the Panasonic was very similar to the Toshiba/Sears set. Back in the 1960's, there was a lot of "cross-pollination" in Japanese electronics. |
#35
Some looking at the Sams listings of the era shows my set as 838-3 in late 1966 and the lowest number in the Sams scheme among the Panasonic listings. The rest are 200+ above this set. Not sure what to look for under other brands. Perhaps the first Pana import? The Tom Genova pages are far before mine and probably domestic only.
I'm thinking that the early Toshiba/Sears/others had the 21" delta CRT build via RCA license on smaller CRT's. Mine does not. Panasonic "Just slightly ahead of our time." as they used to advertise.
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. Last edited by Dave A; 04-15-2013 at 08:07 PM. Reason: typo |
#36
Panasonic '66, Sams 838-3
Hello, Dave A,
II checked yesterday, and found that I DO have an extra copy of Sams 838-3, for the Panasonic Model CT-66! Send me a PM if you still need it!
[B]"Bee care-eh-full to don't broke thee pic-sher tee-yube!" :-) |
#37
Kicking this back alive as I got back to the set today in porch cleaning. Powered up and still same no vert. Line only. I want to check the crt before I go further. It's acting dim. It is a 490HB22 and I cannot find it nor does my Beltron go near this. If anyone has a pinout I can go there with my adapter clips.
#38
Sams tube substitution book shows a 490HB22 crosses to a 19EXP22
#39
The tube, valve compliment are European types, seldom used in US products except for some Motorola models. ESRC has a lot of those tubes for a buck each. |
#40
Nice score that 1966 "Panasonic". I think it's extremly rare!
