Old 03-11-2013, 11:59 AM
rickfray's Avatar
rickfray rickfray is offline
21EAP4 mod
I have a Predicta Holiday with a 21EAP4 tube and when removing the main circuit board, noticed there is a component not on the schematic that is connected to the binding post (don't have the number handy at the moment) which is normally where the CRT cathode connects to. A picture is below. It looks like an RF choke maybe? Any idea what this would be for? Should I remove it since it isn't on the schematic?
http://videokarma.org/picture.php?pi...016515&thumb=1
Thanks
Rick
Rick Fray
Cibolo, TX
Novice vacuum tube fan
Old 03-11-2013, 12:36 PM
The pic is too blurry to make out, but I'll take SWAG that it's a spark gap.
Old 03-13-2013, 10:32 PM
I can't see any picture at all.
Old 03-13-2013, 10:37 PM
rickfray's Avatar
wow that would electrifying. Assume you were kidding. Here's a hopefully better picture. I'm pretty sure it's an RF choke - question is what would it be used for since it's not on the schematic and do I need it?
http://www.videokarma.org/picture.ph...pictureid=3366
Rick Fray
Cibolo, TX
Old 03-13-2013, 10:40 PM
I'm still not getting a picture, just a single pixel GIF
Old 03-13-2013, 10:43 PM
You can see all his Predictas photos in this album: http://www.videokarma.org/album.php?albumid=616
They are on the small side though.
Old 03-13-2013, 10:53 PM
StellarTV's Avatar
StellarTV StellarTV is offline
It's a peaking coil... no idea why that's there; I've never seen that installed on a stock Holiday.
After you get it going, see what the difference is with/without that peaking coil.
Old 03-14-2013, 12:47 AM
The first link gives me a one-pixel picture, too, and the second one shows several components including a couple of "bumblebee" capacitors. Those need to be replaced, of course.
Old 03-14-2013, 02:36 AM
Tim's Avatar
Tim Tim is offline
I believe that the coil pictured is shown on the Sams schematic as L14. Used in some runs and not others. The sets I have restored have had it.
Tim
Old 03-15-2013, 12:41 PM
rickfray's Avatar
OK. I just got the Sams schematics and will lokk at that. I was going thru the Philco docs against the main board last night and noticed some drastic differences in the values of some of the bumblebees vs the parts list values. Does someone have a source on how to read the BB values? I'm not sure whcih end to start at and am not sure what all the bands are for. I'm guessing some for tolerance.
Sorry about the small photos-still trying to figure that part out. The originals are large high res ipad fotos, but not sure how to disply them properly in a forum post yet.
Rick Fray
Cibolo, TX
Old 03-15-2013, 12:43 PM
rickfray's Avatar
Roger on the bumblebees - that was my plan. My post was just focusing on the coil attached to one of the wirewrap posts that goes to the CRT cathode.
Rick Fray
Cibolo, TX
Old 03-15-2013, 12:47 PM
rickfray's Avatar
Nevermind - just googled and got the following links to Bumblebee info
http://classicamplification.net/Guit...Bumblebees.htm
http://www.pickguardian.com/pickguar...ee%20Chart.pdf
Rick Fray
Cibolo, TX
