Old 11-17-2012, 01:43 PM
lnx64's Avatar
lnx64 lnx64 is offline
Look what I found!
Wow look at this thing, it's pretty clean too! Looks like some of the caps have been replaced at one time already, so it's previous owner hopefully took care of it. I have NOT plugged it in yet, waiting on recommendations from you guys. Keep in mind, I don't have a variac at the moment.
http://img.photobucket.com/albums/v3...n/IMG_1417.jpg
http://img.photobucket.com/albums/v3...n/IMG_1413.jpg
http://img.photobucket.com/albums/v3...n/IMG_1414.jpg
http://img.photobucket.com/albums/v3...n/IMG_1415.jpg
http://img.photobucket.com/albums/v3...n/IMG_1418.jpg
Old 11-17-2012, 03:02 PM
lnx64's Avatar
Is it ok to just plug in, since it's not a high voltage TV?
My little sister wants to see it run. And to be honest, so do I.
But if it's not safe, I won't. Patience is a virtue.
The store that sold it to me said it worked when they plugged it in.
Old 11-17-2012, 04:40 PM
lnx64's Avatar
Ok I used a Kill-a-watt meter as a means of measuring it's current draw, and it was fine.
Powered up, and she sounds BEAUTIFUL! There's apparently still broadcasts on shortwave.
Old 11-17-2012, 05:48 PM
It's AMAZING how much performance the Germans could wring outta those sets on just a VERY few Tooobs...
Old 11-17-2012, 06:04 PM
lnx64's Avatar
Oh I hear that! It gets quite loud.
Old 11-17-2012, 06:54 PM
Well, not only were they LOUD, but they sounded good, & the ones I've been around were QUITE sensitive...Those radios were a very visible part of the German "Economic Miracle" of the Fifties-Sixties, where a shattered, defeated country pulled itself up by its bootstraps...They helped establish the "Quality" reputation Germany enjoyed for their goods...
Old 11-17-2012, 06:57 PM
lnx64's Avatar
Very true.
It's FM tuner needs a slight alignment though, To get 104.1 to come in, I need to tune to 107.
Oddly, the tuner dial does go to the propper edges and stops, but I can only go as low as 88MHz (like it should), but the highest it goes is about 105.9.
Old 11-17-2012, 07:33 PM
lnx64's Avatar
Here it is.
http://www.youtube.com/watch?v=fWfy6NG6EMA
Old 11-18-2012, 12:20 AM
lnx64's Avatar
Btw, what's the pinout on the Tape port? I'd like to be able to plug another source into it.
Old 11-18-2012, 01:50 AM
lnx64's Avatar
Well the FM died. AM and shortwave still work.
I was on short wave, and turning the dial all the way to the left, and it hit the end, and it popped, made the magic eye tube blank out and the light flash. short wave continued to work, but when I went to use FM, it was dead. If I turn up the volume all the way, I can partially hear reception, but the eye tube shows no tuning whatsoever.
Old 11-18-2012, 09:30 AM
Reece's Avatar
Reece Reece is offline
Check that the tuning cap plates aren't touching at the fully meshed low end of the dial.
Reece
Old 11-18-2012, 11:47 AM
lnx64's Avatar
Ok. If they were what would they have taken out? Cause am and fm are different tuners and it appears the am/sw tuner knocked out fm. If I crank the volume I can sorta make out fm reception a little but barely.
Old 11-18-2012, 01:20 PM
lnx64's Avatar
So here's what I found. On a oscilloscope in not seeing any activity from the fm tuner.
Maybe the ecc85?
Upon looking under the chassis, all electrolytics seem to have been replaced already. But it may need orange drops though (if that's what they are called).
Old 11-18-2012, 04:07 PM
Reece's Avatar
On a radio this old, there could be slight corrosion on tube pins. Get the pins wet with cleaner and then insert/remove several times into each socket to improve connection. This might be the only problem. You'd have to pull the chassis to check the tuners.
Also, the piano-key switches on these radios need cleaning: spray, work switch on/off several times. Again this is an out-of-case operation.
Reece
Old 11-18-2012, 05:24 PM
lnx64's Avatar
Chassis is pulled. Also did actually clean the tube pins and piano buttons. They were crackly.
Still no fm.
