Old 10-27-2012, 01:29 PM
kx250rider's Avatar
REAL TVs have TUBES!
Are there 4 wires to the ON/OFF switch? If so, you cut in a standby supply to the CRT when the main is cut off. Sony and Toshiba, along with most of the Korean sets did that in the 70s-80s, and many others did too. That's my guess, and a quick look at the schematic would tell all.
Charles
Old 10-27-2012, 02:13 PM
Originally Posted by lnx64 View Post
No cats. I'm allergic.
I have a killawatt meter, I could use that.
Too bad, no cats. I have three black cats.
My Watt-watcher is a great item to have around. I use it for a lot of diagnostics.
That set seems to be a little new to have a standby CRT heater circuit.
Old 10-27-2012, 11:20 PM
lnx64's Avatar
lnx64 lnx64 is offline
Just double checked, it only has two wires. Inside is this however, stamped on the side. Doesn't reveal too much though.
http://img.photobucket.com/albums/v3...n/tvlayout.jpg
I did notice an extra transformer near the flyback though.
Old 10-28-2012, 11:29 AM
The small transformer near the flyback is the horizontal driver transformer.
Looks like a mouse was in there nibbling on the labels.
Old 10-28-2012, 04:06 PM
lnx64's Avatar
Hmm ok.
T601, in the audio circuit, gives me good hopes for being able to install a small headphone socket on the side of the TV. I'd assume the transformer is isolating the speaker from the rest of the circuit, so headphones would be safe.
Old 11-01-2012, 12:15 AM
rpm1200's Avatar
rpm1200 rpm1200 is offline
Ever get to the bottom of this? Did you try putting it on the kill-a-watt and see if it's drawing any power when off?
Old 11-01-2012, 12:41 AM
lnx64's Avatar
Yea, oddly a killawatt is reading 0 watt draw. So I don't know how acurrate those things are when it comes down to low wattage readings. Because it fluctuates between .3 and 0 watts. I'm sure those filaments draw more than that.
Old 11-01-2012, 08:07 AM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
I use those to work on even little netbook computers....so if your particular Kill-A-Watt unit is working, they are good down to pretty small loads.
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 11-01-2012, 10:25 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
What is the smallest load yours will display?
Old 11-01-2012, 01:06 PM
AiboPet's Avatar
"micro" and quirky
I don't have it here at work with me today, but I've seen single watt numbers in some netbooks in "sleep" mode. I don't recall if I have ever seen less than one watt...but know for sure I've seen down to one, as the little ASUS 900HA netbook "sleeps" at around 1.5W. I do know it will register ZERO watts....just can't recall if I have seen "500mw" or " .5 " before.
If you are seeing anything less than 5-10 watts.....you are not generating any noticeable heat, nevermind enough to actually warm the top of the set. I know the little wattage display on my APC ups I have on my "entertainment" center in the front room shows 18 watts at "off"....but that damn Cox cable box DOES seem to ALWAYS be warm whether off or on. I'm getting that "18w" display on the APC with the Samsung 55" on standby...cable box on (or off...no difference)...and my little Archos AV700 playing into the little HLLY transmitter (those two run 24/7).
So actually.....I don't know what to believe sometimes, but the Kill-A-Watt always seems to give me a much more believable number (I should put the Kill-A-Watt after the ups someday and see)
I'm not sure if the UPS is also showing me what it's OWN circuitry is drawing as well...but I suspect it's just the load to it's sockets in back. It will go to zero if nothing is plugged into it...and will go back and forth between 2 and 3 watts if I unplug JUST the Scientific Atlanta HD box (and THAT thing gets pretty warm!)
Old 11-01-2012, 01:37 PM
lnx64's Avatar
Well here's what I've noticed since. No, there hasn't been any more heat noticed. But, the filaments in the CRT do continue to glow after power off. Could they draw 0.5 watts and still have a noticeable glow?
I don't know why I felt it warm before. It was warm, but I just don't know why.
Old 11-01-2012, 03:38 PM
My K-A-W model P4460 will not indicate the power of a single 4 watt night light bulb, but if I turn on 2 of them, it indicates the correct 8 watts.
Old 11-01-2012, 06:56 PM
AiboPet's Avatar
"micro" and quirky
Just tried real quick my KAW P4400
Running the wall wart for the Panasonic TR-1020 (REAL little TV)...the thing draws 2.3w charging it's internal battery...and climbs to 5.4w when I turn the little 1020 on.
So I guess it does appear to measure to .1 watt increments.
Old 11-01-2012, 07:03 PM
ctc17 ctc17 is offline
what is the model number and exact year. cant we look at a sams on this and see exactly what is going on?
Sounds like it doesnt meet omambas zero energy no coal powered TVs energy star agenda. Let me help you get to the bottom of this before the EPA SWAT team shows up and confiscates all your electronic toys...
Old 11-01-2012, 07:31 PM
lnx64's Avatar
SAMs website doesn't find this TV. It finds the chassis though. I'm not at home but the pic I posted earlier should show its chassis number.
