Old 09-18-2012, 07:51 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
Sylvania halolight combo!
1953 sylvania halolight combo (colonial) model
radio/ record player work tv needs a high voltage cap
With ALL the ORIGINAL INSTRUCTIONS!!!!!!!!
Looking for zenith cobramatic parts
-johnny the raster master!
Old 09-18-2012, 08:18 PM
radiotron's Avatar
The doors arent that stable thogh becouse it weighs almost 300 pounds,
therefore someone held onto the doors while cariing it their still atatched though
Old 09-18-2012, 08:49 PM
there is one of those in ny cl
http://hudsonvalley.craigslist.org/atq/3261235466.html
yea.
Old 09-18-2012, 10:07 PM
radiotron's Avatar
yea.
the combos are a whole lot rarer thogh
Old 09-18-2012, 10:29 PM
The one on CL could be in far worse shape than the combo is. The set in New York state has no knobs and the condition of the TV is unknown, which should send up a red flag immediately. I don't like to guess about these things, but the set on CL could be just about worthless, except for parts. (I would not dream of plugging this one in, except through a Variac -- and even then I wouldn't expect much, if the set worked at all.) The owner may have cabbaged the knobs for use with something else, and the tubes could be missing as well.
Old 09-19-2012, 08:10 AM
radiotron's Avatar
Mine the radio, and record player works, but the tv needs a high voltage cap
(working on that now)
Old 09-19-2012, 08:39 AM
DavGoodlin's Avatar
Motorola Minion
Tubes are very easy to find for these sets. I would take it if it was closer.
Old 09-19-2012, 11:01 AM
snelson903 snelson903 is offline
wow ,thats a good deal, someone needs to get that one before it becomes a art project that's the kind they go for.
Old 09-19-2012, 03:26 PM
radiotron's Avatar
almost shorted the radio out, luckly i didnt! It was playing, somehow a piece of the pilot light broke off touched the negative, and positive it tured off smoke started pouring out the back, it was BAD:tears
Old 09-19-2012, 03:56 PM
Did you turn it off in time to prevent any more damage or a fire? How much damage to the chassis was there, if any? I personally cannot imagine how a broken pilot light (most of them in old radios are #47s) could cause a major short such as you describe, unless the pieces of the bulb somehow shorted a B+ point to ground and overloaded the power transformer. That may be where the smoke was coming from.
Hope you get the radio working again. These old sets can work quite well when they are in good shape. Recap yours (at very least replace the filters), and you will have a set you can be proud of.
Sylvania made some excellent TVs in their day. The Halolight cast a soft glow around the TV picture, increasing the contrast and also allowing the use of the TV in an otherwise dark room -- although I'd think the picture could be even better with at least one room light on in addition to the Halolight, to say nothing of reducing the possibility of eyestrain, as could happen if one watches TV in a totally dark room (most eye doctors will warn their patients against this).
Good luck.
Old 09-19-2012, 04:14 PM
radiotron's Avatar
Good luck.
yes i turned it off in time theres no damage to the chaissis whew the radio still works, what happened was the solder on the bottom cracked slid over, and touched the to together
it hasnt been recaped, but the caps are really strong
Old 09-19-2012, 07:04 PM
radiotron's Avatar
any idea what these are inside the high voltage cage theres no ib3, but 2 glass rods with 3 connections caps?
Old 09-19-2012, 07:31 PM
"The one on CL could be in far worse shape than the combo is. The set in New York state has no knobs and the condition of the TV is unknown, which should send up a red flag immediately. I don't like to guess about these things, but the set on CL could be just about worthless, except for parts. (I would not dream of plugging this one in, except through a Variac -- and even then I wouldn't expect much, if the set worked at all.) The owner may have cabbaged the knobs for use with something else, and the tubes could be missing as well. "
Well, if I were interested in this set, I see that for a NY set, the chassis is rust free, so is the power transformer, the cabinet has no mold, or water damage, and the face is clear and clean. No picture tube brightner. I think that for the price this set is just three ticks below peach. Even the part of the cabinet back that sits on the ground that is unfinished looks like it has been in a nice dry climate. It certainly looks better than sets I have seen for $50. or more.... CL Often has some good finds.
Old 09-19-2012, 07:49 PM
Type 5642 HV diodes:
http://www.r-type.org/exhib/aai0016.htm
Widely used in Tektronix oscilloscopes of the era, and a few TVs.
Here are a few on the 'bay:
http://www.ebay.com/sch/i.html?_trks...diode&_sacat=0
Not affiliated,
Old 09-19-2012, 08:07 PM
ggregg's Avatar
ggregg ggregg is offline
No they're not. How can a fifty plus year old cap be really strong? Run it till you fry it, I guess.
