Old 08-02-2012, 07:40 PM
silvertone roundie
hey all yes me again, this 63 silvertone i have has like a ghost bar in the middle of the screen but certain scenes its there others its not. and the colors seem to be brighter on the bottom of the bar then the top and with scenes the bar moves around up and down alittle. its always had it but sometimes its alttle more lately. most old tvs i have seen have this but any suggestions on how to get rid of it. i have changed all the caps in the verticle board so im lost now.
Old 08-02-2012, 07:59 PM
I have a vcr that blinks 12:00 all the time so I put a piece of tape over it.
Old 08-02-2012, 08:01 PM
well to fix that, all you have to do is set the time.......
Old 08-02-2012, 08:07 PM
what kind of tape should I use....
Old 08-02-2012, 08:17 PM
What's up with all the funny replies lately?
Old 08-02-2012, 08:26 PM
i guess all i can make of it is no one has the right answer,lol,lol......
Old 08-02-2012, 08:29 PM
Bill R Bill R is offline
What about he power supply caps? Have they been changed? I would also check the tubes for heater to cathode shorts. Also resolver all the ground connections and be sure all the tube shields are in place.
Old 08-03-2012, 12:17 AM
ctc17 ctc17 is offline
:b anana:
I bet its you source. Crappy modulator in the cable box or whatever you source is.
Old 08-03-2012, 12:31 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
I agree. I get jailbars with the cheapo modulators. The Rat Shack(1980's) one I have seems to be the best. The one built into my digital converter box sucks. Very crappy sound and only an OK picture. Could be a crappy cable or balun. Try a different channel. 4 instead of 3.
Old 08-03-2012, 12:46 AM
Almost sounds like a drive line. Could be a weak output tube or mis adjusted lineraty coil.
Dave has a good solution, paint a racing stripe over the affected area.
Old 08-03-2012, 07:15 AM
the only thing i am using is a directv box and my other sets dont do this with the same box. i checked tubes all there good.
Old 08-03-2012, 09:28 AM
Model? Is this one of those ctc11 clones? can you post pic?
Old 08-03-2012, 09:50 AM
its the ctc12 clone the set that is on my posts in the corner. its kind of hard to see but what seems like a black bar under the phone number is what moves up or down with different scenes. even movement in the picture moves this bar around ,its like the bar trys to follow the movement and it seems like in the verticle. how criticle is tube sheilds because this set may be missing one or 2.
Old 08-03-2012, 10:36 AM
Put you direct tv box on the menu or channel guide and adjust the focus, It looks real soft.
Usually the chroma osc and of tube has shields and I have never noticed any effect.
Try turning the contrast down a tad and see if the bar goes away.
What is the model number? Or sears chassis number?
Old 08-03-2012, 10:47 AM
well i was kind of close with the camera and the contrast i leave just about all the way clockwise because of those 3 color retrace lines they are so much less with the contrast up and down the lines are all over. ill do the focus again. i checked the converge yesterday and it was off alittle, this set was fine now these things are creeping up. oh well its old so it needs tlc. ill have to get back to you on the chassis number.
