Thanks. I'll keep my eyes out for them, but I expect it won't be easy.
I brought the Sonora inside for a closer look. It's one weird set for sure. Continuous tuner using variable capacitors and a voltage doubler for the HV. A 12LP4 only needs 11 KV so I don't see why they bothered with a doubler. ![]() It looks to be in very good original condition. I sure hope that flyback is good. ![]() The cabinet is pretty cheap, but in OK condition. ![]() Just one big problem so far. The NU-Video 12LP4A has excellent emissions, but a stubborn G1 short. I've tried blasting it a few times with my CR70 to no avail. I'll let it go for now and try again another day.
Bob,
The Sonora has filter and bypass caps that just SNAP into a holder!!! Wow Now that makes recapping and restuffing unbelievably EASY! Nice sets, I really like that Westy! Another series of videos will be forthcoming I am sure. Keep up that good work! Matt |
The rubber corner mounts on that Westy may indicate that Philco built the chassis, though it appears to be unique to that set.
We know from Phils experience that at least one Westinghouse has an actual Philco chassis inside. I had my H196 a long time before I realized the lower front trim pulls off to access the adjustments! |
By the way, the schematic for the Sonora is posted at the ETF Site.
http://www.earlytelevision.org/image...2-303-Sams.pdf It's only the schematic but that's all Sams has for it. |
Yes, I recorded some video while poking around these sets.
Thanks for the link. I also found the Sonora in Riders Vol 5. Four pages of info including a parts list and alignment instructions ![]() I was thinking Philco too as soon as I noticed the rubber mounts and perforated chassis. Last edited by bandersen; 07-17-2012 at 02:16 AM. |
That's interesting that the Sonora uses 1V2 for HV rectifiers. I thought those were only used in color TV as the focus rectifier. The schematic is really easy to read too
BTW the building that Westinghouse had in Sunbury later manufactured Celotex insulation. |
I think my 12 inch Westinghouse set uses the 1V2 as a high voltage rectifier...
Am I seeing things or does that Westinghouse have 27 tubes?
Far out that is a lot for a mono set! Impressive
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/ My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn |
27 tubes and 260 watts perfect for making this summer more enjoyable! Now you just need an RCA TK-30 camera chain to go with it
![]() Matt |
You've been getting some neat sets lately, I look forward to seeing 'em running. The bright red paint indicates that 16GP4 is a rebuild. Are you gonna restore the RCA too?
![]() If someone would like it, feel free to contact me. I won't be holding on to it for long. |
![]() Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
