Old 02-27-2012, 10:46 AM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
diagram needed
I just picked up a portable rca model 6-bx-8 and need a diagram please. or the Sams set/folder number for it and my capehart by farnsworth 21n2, thanks.
Old 02-27-2012, 01:22 PM
bob91343 bob91343 is offline
In the Beitman file there are two models, the 6BX8A and the 6BX8B. I didn't look for the Capehart one but it may be in there too.
I got the Beitman files on line; Google them and download the whole thing.
Old 02-27-2012, 03:57 PM
radio nut's Avatar
I've never heard of beitman before but I will try it. I have a riders for the capehart but can't read all of it well. The rca I couldn't find a riders for from nostalgiaiair.
Old 02-27-2012, 04:53 PM
If you are unable to find Beitman, I can look for a link or, failing that, can convert to files which could be uploaded.
Okay try this:
http://makearadio.com/beitmans/index.php
Old 02-27-2012, 05:38 PM
radio nut's Avatar
I found it, thanks. I will download what I want tonight after I get home from work.
Old 02-28-2012, 12:08 PM
radio nut's Avatar
Beitman didn't have the diagram for the capehart, does anyone have a master index to look that sams up for it?
Old 02-28-2012, 01:19 PM
It's not in Sams.
Old 02-28-2012, 02:57 PM
radio nut's Avatar
thank you for checking
Old 02-29-2012, 07:09 AM
Reece's Avatar
Reece Reece is offline
Is this it?
http://www.nostalgiaair.org/PagesByM...8/M0005788.pdf
Reece
Old 02-29-2012, 02:55 PM
radio nut's Avatar
For the capehart,yes.That is the only one I can find. I do not have riders at home to look at and nostalgiaair's copy is fuzzy on the diagram itself. A couple of the micas I need to replace are in the fm detector and osc. circuit. the fm staions from about the middle of the dial to the right float for about 20 minutes. ex. 107.5 starts at 106 something and drifts over to 108 and then stays there. I can't read all the values or the parts list number on the diagram well enough to be comfortable to change them . atleast one of them I can't tell the color code on the mica itself. Maybe my electronics cleaner took the paint off? So I'm not sure what caps to buy. My eyes aren't what they used to be.....
Old 03-01-2012, 07:52 AM
Reece's Avatar
I looked and can read the mmf. values of the micas on the NostalgiaAir schematic. If you can identify the caps you want by where they are located in the actual set, i.e., going from terminal X to terminal Y, we could locate on the schematic and determine the value.
Reece
Old 03-01-2012, 04:48 PM
radio nut's Avatar
Ok Reece, lets see... on page 22 of the pdf which is the second part of the diagram the first cap is the one coming off of the grid of the fm osc. tube that is in parallel with the 33 k resistor. #2 is the cap going to pins 4 and 5 of the 6h6 disc. tube. #3 and 4 are the two caps in series from pin 6 and 3 of the same discriminator tube 6h6.
Old 03-01-2012, 04:50 PM
radio nut's Avatar
Oh, by the way what does" N-750 " below the cap on the diagram mean? There are a couple that have that written by them.
Old 03-01-2012, 05:12 PM
N750 means negative coefficient of capacitance with temperature, -750 ppm/C
Old 03-01-2012, 05:47 PM
radio nut's Avatar
So that would be a temperature stable cap? correct?
