Old 01-15-2012, 06:25 AM
Rickey Rickey is offline
Tube identity.
Can anyone identify this tube?
It is from a 1937 circa table radio, that I can't identify either!
Old 01-15-2012, 06:31 AM
The tube came from this radio. It has six tubes sockets, 25z5-6d6-6c6-43-?-?
The missing tube is a 4 pin socket and the other one is the previous picture.
The label reads Plant A, Chicago.
Old 01-15-2012, 07:20 AM
stusnyder's Avatar
Find the manufacturer and model. Once you find that you can look it up on a schematic or in riders.
Old 01-15-2012, 07:35 AM
I can't find the manufacturer or model, that's why I put in on here! Lol
Old 01-15-2012, 08:39 AM
Reece's Avatar
Reece Reece is offline
The 25Z5 and 43 are 25 volt tubes, and the 6 volt ones and probably the missing one all add up to 68 heater volts. The tube in your picture must be a ballast tube, which is a wire wound resistor in a glass envelope, used to drop line voltage to 68 volts. Look carefully and see if it looks like that's what it is. Try measuring resistance across all the tube pins and see what you get. Ballast tubes get very very hot in operation.
Is there any writing on the tube base? Try putting the tube in the freezer for a few minutes and then take it out and breathe on it and look around on the glass for a number.
Edit: I can't think of another 4 pin tube that would make sense here. The radio could function with the rectifier, output, and the two 6 volt tubes you have. Perhaps the two four-pin sockets are for TWO ballast tubes. Some manufacturers in the thirties inflated their tube count to make folks think they were getting more radio for the money, where in fact the extra tube or tubes were not needed. Inspecting the way that the sockets are wired would tell you. If the two four pin sockets are wired in series some way it could indicate that they are both for ballast tube impressivity. If that's so there are ways around having to use ballast tubes, which can be hard to find. Time to flip the chassis over and start drawing the actual back into the schematic diagram. I've had to do that on several orphan sets and it's good practice in tracing circuits and in patience! As you go you'll see how the circuits come together. Then you can compare your set with the schematics of sets using similar tubes. There's a lookup table for that at grillecloth.com
Reece
Old 01-15-2012, 01:22 PM
bob91343 bob91343 is offline
Yes that is called a ballast tube, often made by Amperite. Some of them have taps for pilot lamps.
Calculate the resistance and power rating from subtracting the sum of all the heater voltages from the power line and dividing by 0.3 Amperes. If you need 68 Volts from 120 V, then you divide 52V by 0.3A and get about 170 Ohms. It will dissipate about 16W so use a 30 W resistor or thereabouts and mount it clear of components that its heat will damage.
Having said that, you may still be able to find ballast tubes, assuming yours is bad. Measure across various pins to see if you can measure somewhere around 150-170 Ohms. If so, it's probably good.
Old 01-15-2012, 02:53 PM
Thanks guys, this will get me started.
Rickey
Old 01-16-2012, 02:52 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
If you can ever figure out what number that ballast is, try Fair Radio in Lima, Oh. They have a decent selection of amperite ballast tubes.
Old 01-16-2012, 03:29 PM
Thanks, I will !
Rickey
Old 01-17-2012, 03:36 PM
I've concluded it is a185r4 ballast tube. I found it written in pencil, on the chassis!
Rickey
Old 01-17-2012, 08:38 PM
Reece's Avatar
So what is the other 4-pin socket for? Can you tell by the wiring? If this tube is only half the resistance needed, then you'd need two identical depending on the socket wiring.
Reece
Old 01-18-2012, 07:17 AM
Reece, how can I determine the resistance needed? The missing tube,(socket) is wired to the mains and the other ballast.
Rickey
Old 01-18-2012, 09:15 AM
ed857 ed857 is offline
Could the missing tube be the detector, possibly a 37 or 76 tube?
Old 01-18-2012, 12:43 PM
Reece's Avatar
The missing tube has a four-pin socket so is not a 37 or 76. Rickey: what you are going to have to do is trace the wiring around those two four-pin sockets and report it here before we settle on ballast tube(s). My GUESS is this:
1. Power line in goes to first 4-pin. May or may not go to switch first.
2. Wire comes from first 4-pin and goes to second 4-pin.
3. Wire comes from second 4-pin and goes to first heater of the remaining tubes.
4. All the remaining tubes have their heaters connected in series.
Reece
Old 05-05-2012, 05:43 AM
snelson903 snelson903 is offline
i have 3 new in box they used for regulating voltage i think somewhere in my tube schematic books i have the info on them
