Old 10-27-2011, 08:07 PM
Originally Posted by madmike17 View Post
Yes, the vibrator clearly runs. The only solution I can think of is to just turn the vibrator around. Could this be damaging if I'm wrong? What if i just disconnected the center tap to see if there is voltage when the vibrator is switched so that nothing could be harmed?
That's a good thought. But leave C34 in-circuit and disconnect everything 'downstream' from it. C34 can't be hurt by reverse polarity, even with full "B minus" voltage on it.
Also, voltage off the center tap should be DC, right?
Yes. And C34 should provide enough filtering for the meter (Digital meters tend to go nuts on unfiltered waveforms).
Is the truck negative or positive ground?
Old 10-27-2011, 10:08 PM
madmike17 madmike17 is offline
Certified Idiot
It is a negative ground. I believe most positive ground cars were imports.
Old 10-27-2011, 10:15 PM
All the 6V Chrysler product cars i ever dealt with were positive ground also, though there may well have been exceptions.
Old 10-27-2011, 10:26 PM
Certified Idiot
The truck is actually my fathers, and I will check with him tommorow. I am also going to test it tommorow when the battery is charged again. Thanks for the help so far!
Old 10-27-2011, 11:31 PM
6 volt Fords as well.
Old 10-28-2011, 10:54 PM
Certified Idiot
Turns out, the truck is positive ground. with the transformer diconnected, I read 307 volts dc to ground. When I reconnected the circuit, the vibrator didnt even run. After a lot of fooling around with it it finally began to run. Unfortunately, the radio does not work. A hum the same frequency as the vibrator came through the speaker, but nothing else. As i turned the tuning cap, there were crackles and pops from the cap itself. It sounded like high voltage arcing between the plates. Should the rotors have hv on them? I know the stator is directly connected to ground. The vibrator really didnt want to start, I had to tap on it and shake it to make it start. I think I am in over my head. Now what?
Old 10-29-2011, 11:54 AM
Turns out, the truck is positive ground. with the transformer disconnected, I read 307 volts dc to ground.
Now that's with C34 still in-circuit, right? And you're getting 307V positive to ground across C34?
Sounds like something's shorted out on the B+ line, like maybe filter cap C29. Did you replace it after it 'spilled its guts' from reversed polarity?
The tuning cap shouldn't have any signifigant voltage on it, maybe just a few volts max.
Normally the tuning cap rotors are at ground and the stators are the 'hot' side of the cap (unless you've a got a very unusual style of tuning cap).
You might try disconnecting what you did before, leaving just C34 in-circuit, and see if the vib will start up easily. If so, it suggests a heavy short in something 'downstream' (like in C29) lugging the supply down and stalling the vib.
Old 10-29-2011, 12:23 PM
Addendum:
BTW, what are you disconnecting? The break should be at either side of L6, the RF choke directly downstream from C34. That'll be a good opportunity to check for a B+ short 'downstream'.
Old 10-29-2011, 12:31 PM
Certified Idiot
The 307 volts was positive in relation to ground. It was measured with the .1mfd cap connected to the secondary center tap and nothing else. I did replace the electrolytic that died. I didn't think to check the actual voltage on the tuning cap, but I'm pretty sure it was sparking. I actually found that the rotor was rubbing, so I bent one of the plates over a little. I made a mistake in typing, the rotor is actually connected to ground not the stator. When I disconnected the hv circuit again at said point, I got 267 vdc. This may have been due to the tubes being in and drawing heater current, while last time they were not. Once again I had to tap on the vibrator to get it started.
Old 10-29-2011, 12:36 PM
Certified Idiot
Also a side note: do you think there is a place where Ken-Rad ST style tubes can be found? I would like to have them all match the originals. The 6B8G and 6N7G are replacements.
Old 10-29-2011, 04:46 PM
bob91343 bob91343 is offline
I assume you have replaced all electrolytic capacitors. If not, do that before any more struggling.
Old 10-30-2011, 08:53 AM
Certified Idiot
The only capacitors that havent been replaced are three very small value micas that I couldnt find replacements for.
Old 11-25-2011, 07:06 PM
DavGoodlin's Avatar
Motorola Minion
Madmike
Those vibrators with mechanical contacts are trouble. There is a place in florida that makes them exact for your unit in a solid state version. I restored a negative ground 53 Chevrolet radio. A total recap was needed also. According to Justradios.com, mica caps rarely go bad.
http://www.radiodaze.com
Dave G
