#31
Shouldn't the screen controls be up as well? If you reduce the screens, the guns will emit less electrons and of course it will be dim. Are drives the same as background? Quote:
Bad pots?
Evolution... |
#32
Zenith's first wireless electronic remote control TVs used the SC-100 one-button remote. The single button simply changed channels in one direction and could turn the set off when the tuner reached an unused channel. This system likely unnerved some viewers if they overshot the channel they wanted to watch; this meant having to hold the button down while the set's tuner clunked through 13 channels (counting the UHF position, if this series had one). The advent several years later of random-access tuning, using 10 buttons on the set and/or on the remote, now standard on all TVs, solved this problem, as now the viewer could select the desired channel, and go instantly from one local station to the next, without having to see five to twelve channels (depending on how many local channels the viewer's area had) of nothing but snow in between.
#33
In the late 70's, the Olson Electronics store in Chicago had a surplus add-on motor for TV tuners for sale for maybe $5, and it included a power switch in its presumed-UHF position as well.
#34
Well the sam's arrived from banderson today (thanks!), and it definitly uses a wierd CRT set up procedure(compared to the Zeniths and RCA clones I'm used to) the cathode levels are set by pluging the wires that come from the socket into several terminals rather than by potentiometers. The RGB background controls(miniman had the name right first) adjust the grid bias, and a single "master screen" controls the the three screens the leads of which are conected together just after leaveing the socket.
When I get the chance I'll attempt the grayscale procedure, and see if I can get a good picture. Tom C. |
