Old 03-21-2011, 11:07 AM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Trinitron CRT swap question
I've got a Sony video monitor with a bad M49KGH11X CRT, and just happen to have a good M49KGH20X, does anyone know if they will swap? I've looked high and low on google and can't find data sheets on either one or any cross reference guide that mentions them.
Old 03-21-2011, 12:42 PM
kx250rider's Avatar
REAL TVs have TUBES!
Although I don't remember ever seeing either of those numbers, I'd try it as long as the socket pinout is the same. If unsure, look it up on a CRT tester setup. My guess is that if they are the same pinout, they'll swap. Watch for things like the mounting tabs being differently installed, or if it's bonded yoke, that might likely be different.
Charles
Old 03-22-2011, 10:33 PM
1993ctc175 1993ctc175 is offline
I have a couple of 32" trinitron CRT's in my mind.
I have a couple of Sony 32" tv. The First is the KV32V26 (bad PWR SUPPLY) and KV 32XBR37.
I am planning to do so on the 32" CRT's to see if which one is better.
the CRT from KV32V26 is High-Black but the KV 32XBR37 is not but it is in fair condition.
wish me luck!!
Old 03-23-2011, 09:36 AM
kc8adu's Avatar
kc8adu kc8adu is offline
the difference in the 11x vs the 20x will be mounting lugs and or yoke.tube is the same.
email for more info
Old 03-23-2011, 10:13 PM
matt_s78mn's Avatar
Thanks for the information. I should have a chance to try the swap either tomorrow or Friday, will let ya know the results.
