Old 03-21-2011, 09:28 PM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
Mode change
Ok.. I switched to Linear Mode and everything shows now. That's nice to have a choice. Great Forum software!
Buzzsaaw
Old 03-22-2011, 08:15 PM
Buzzsaaw's Avatar
Made just right!
I was looking at the Retro-Tronics backs and came across this one: http://retro-tronics.com/itemDetails...1+Antenna+Form and thought this would be perfect for winding a Loop Antenna on. I should see what they'd charge to cut and odd number of slots around the edge of the back for the Hippo.
Retro-Tronics also has a picture of the Clip I need to hold the back onto the Hippo... : http://retro-tronics.com/images/trimouts.jpg They have a real nice website. Lots of pics of radios I've never heard of...
Buzz
Old 03-23-2011, 08:03 AM
Reece's Avatar
Reece Reece is offline
Yes it would probably work, but with a saber saw and some 1/8" masonite (from home center or lumber yard) you can cut any form or back that you need, real cheap (that's me!)
Reece
Old 03-29-2011, 06:44 PM
Buzzsaaw's Avatar
Wink Ant made.
Here's some pics of an Antenna I made and the back before painting:
The Antenna Loop is just attached with clips for now until I see how it works (after recapping). 28 ga wire about 45 feet for 3 Ohms. (22.8 raps at roughly 2 feet per wrap). I left it long so I could take some off if needed.
______________________
Buzzsaaw
Sunlitedreams.com
Old 03-30-2011, 05:38 AM
Reece's Avatar
Wow, that's a beautiful job! Very nice.
Say, it just occurred to me, the title of this thread, "My old Hippo loop antenna," was a phrase never ever uttered before in history!
Reece
Old 03-30-2011, 10:23 AM
Buzzsaaw's Avatar
Wink Looped
Yes.. that is a goofy phrase. But it's better than a "looped Hippo!"
Buzzsaaw
Sunlitedreams.com
Old 03-30-2011, 03:15 PM
That looks pretty good, Is that wire wrap wire? IIRC, that kind of wire is silver plated, which would be good for this sort of work. Or untinned copper wire, like magnet wire (used in transformers and coils) is also a good choice.
Old 03-30-2011, 04:26 PM
Buzzsaaw's Avatar
Smile Wire type
Hi,
That's just plain ol' enamel coated copper wire.. 28ga. The kind you would use for winding a toroid.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 04-06-2011, 06:39 PM
Buzzsaaw's Avatar
back and a goof up
Here's a picture of the back painted and the UL and Philco lables in place. If you notice, I goofed up.! The ac cord comes out of the middle of the radio.. Guess what's in it's way?
Oh.. boy!... I'll fix it.
Buzz
Buzzsaaw
Sunlitedreams.com
Old 04-06-2011, 07:59 PM
Buzzsaaw's Avatar
Smile Oh.. I see!
I looked at the made by Retro-backs. I should have looked at Banderson's back picture:
Would have helped a bunch!
Buzz
Buzzsaaw
Sunlitedreams.com
Old 04-06-2011, 09:01 PM
Bummer. Can you make yours fit or will you cut out a new one?
P.S. Retro-tronic does make one identical to the original. http://www.retro-tronics.com/itemDet...ck+%28Black%29
Old 04-06-2011, 09:58 PM
Buzzsaaw's Avatar
Bummer...
Oh.. well..
I think I'll try to make it fit until I find some more Masonite. I still have my old pattern.. I'll modify that and build a new one. I'd like it to be close to original.
Hay.. this is good practice ya know...
Buzz
Buzzsaaw
Sunlitedreams.com
Old 04-16-2011, 02:08 PM
Buzzsaaw's Avatar
Smile Anyone ever do this?
I tried to think of a way to attach the Hippo Back Antenna to the radio without soldering/un-soldering when it gets removed again later on.
I used molux connector pins and 1/8" heat shrink tubing:
Yes, I know it isn't original but I already have a screw holding on the pilot light. (which burned out). I looked all over town for a #47 6 volt bulb. No such critter here! I see lots on line..
Buzz
Buzzsaaw
Sunlitedreams.com
