Old 12-17-2010, 12:14 AM
Stereo2 Stereo2 is offline
VK Member
Looking for a 1968 Mopar car radio schematic
Hi all.
I am looking for a 1968 Plymouth Bendix Mark 1 (284 890)
ser. 9FBBA AM/FM car radio schematic.
Basicly the AM is not working, FM works but not 100% & it also has a split plastic tuning gear. Any Help would be much appreciated.
Old 12-17-2010, 12:41 AM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
I bet drh4683 can help with this.
Old 12-18-2010, 07:50 PM
VK Member
Maybe these photo's may help.
I did unsoldered one pin on one of the resistor/capacitor networks which it brought back the FM to a 100% working condition. You may see the unsoldered pin in PCT0010a.
Old 12-18-2010, 08:03 PM
VK Member
Some more photo's
Old 12-18-2010, 09:35 PM
peverett peverett is offline
Check the Howard W. Sams website. Sams has an auto radio series of schematics. Of course, Sams does charge for these.
Old 12-19-2010, 04:58 AM
VK Member
Thanks Peverett. E-mail sent.
I would appreciate any other Tech tips.
I did reversed two transistors (dia. A ) with no change to AM or FM. I was hoping if it was a bad oscilator transistor it would show some kind of change.( I.F. would be poor but AM oscilator would tune in?)
There is a diode ( dia. B ) that I pulled & it measures like a diode, but I can not identify. (Zener?) Which lead me to unsoldering Cap/resistor network pin, in turn makes the FM work perfectly.
Old 12-19-2010, 10:11 AM
On the Howard W. Sams website, you can enter the radio model number and see if they have the schematic.
Old 12-22-2010, 01:03 AM
VK Member
Solved problem
I started removing I.F. coils & inspecting the winding in the coils. On the third I.F. coil removed, I found one of the windings corroded, but fixable!
Fixed without any schematics. AM & FM are working!
Now I'll try to fix the broken plastic gear. Any suggestions?
Old 12-22-2010, 02:16 PM
Reece's Avatar
Reece Reece is offline
If the gear is otherwise whole, you could superglue it with the proper one for plastics. I used it on a plastic gear in a tape player successfully. If there's room on the side of the gear, sand lightly and superglue thin aluminum "band aids" across the crack.
Reece
