Old 10-04-2010, 02:48 PM
tvcollector's Avatar
Sencore CR70
Hello, I'm thinking of buying one of these, but doesn't have the manuals, i've never used one before, so is it worthless without it? I have an old tv the needs testing of the picture tube
Old 10-04-2010, 03:34 PM
I can scan the manual for you. I think several other member have one too. I hope you have the adapters - especially the universal adapter. You'll need that for most old CRTs.
Old 10-04-2010, 07:36 PM
it says this
Includes: The beam builder, power chord, univrsal adapter 39G170, e3896 STYLE 2464 CABLE,
This is going to be used on a late 60s motorola quasar, and 70s and 80s television sets too, but mainly the motorola quasar for now, i'll worry about the other sets another time.. Let me know if I'll be good to go..
Thanks..
Old 10-04-2010, 10:14 PM
Sorry, I don't know. I've only used it on pre 1952 CRTs and the universal adapter covered them all. I do know there are at least 4 adapter pods - most have a different socket on either side. I suspect the CRTs from the 60s-80s will not use the universal adapter.
If you can give me some CRT model #s, I'll look them up and check.
Old 10-04-2010, 10:33 PM
Heres a pic of the tags, couple of numbers..
Old 10-04-2010, 10:49 PM
OK. That's a 25ZP22 and you'll need adapter #2. I believe a complete set is #1 thru #10. I only have 5,6 and 7.
Old 10-04-2010, 10:54 PM
i'm looking at this auction and looks to be no #2.. Also i just located another auction and also has the same exact adaptors, and that auction says complete with all adapters. Are you sure its a #2?
http://cgi.ebay.com/SENCORE-CR70-UNI...item20b42e5d3b
Old 10-05-2010, 12:45 AM
That sure looks like a complete set of adapters to me. See how they're labeled 1&2, 3&4 ? There's a socket on either side of the adapter so that makes ten plus the universal adapter in the upper-left.
Old 10-05-2010, 07:48 AM
oh ok got you...
Now I wonder if i should trust the auction. Not fully tested..I don't know how these things are reliable, most auctions i'm looking at all say sold as is and most of them say they just did a power on test
Old 10-05-2010, 04:01 PM
I don't know about their reliability either. All I know is I got mine untested off ebay and it works fine
Old 10-05-2010, 09:59 PM
I just bought this one in the link for $125 including the shipping. They say it came from a school auction.. I'm hoping it works..
http://cgi.ebay.com/ws/eBayISAPI.dll...X:eRTM:US:1123
Now will the CRT have to be discharged before using this tester/rejunvinator?
Old 10-05-2010, 11:49 PM
No, but you should discharge it if you ever need to go anywhere the HV lead or flyback.
Old 10-05-2010, 11:56 PM
ok, thanks for your help bandersen....
Old 10-05-2010, 11:57 PM
Exclamation I'm an idiot
When I bought my CR70, the seller told me all the adapters were missing. Having never seen or used one before, I just took his word for it. I made up my own UA and eventually scored a few real adapters.
Just now, I stumbled across this listing on ebay: http://cgi.ebay.com/Sencore-CR70-Uni...mZ160487550983
I had no friggin' idea there was a secret compartment in the lid
Lookie what I found lurking in mine
Guess I got a better deal than I realized - only the 3&4 is missing.
Old 10-06-2010, 12:07 AM
Good luck. If you hadn't got me looking, I never would have realized I had more adapters hiding under that lid!
