Old 08-17-2010, 01:46 PM
sampson159's Avatar
sampson159
beautiful set.glad it came out for you.those 21cyp22 crts put out a terrific picture.i have 2 of them and they stand against any tube,anywhere.the reds are so full and rich.i am happy for you!
Old 08-17-2010, 01:54 PM
A thing of beauty, indeed! Congratulations!
Old 08-17-2010, 01:59 PM
Very nice!
Another lovely vintage color brought back to life... was the '7 the first RCA color set with remote?
Old 08-17-2010, 04:12 PM
holmesuser01's Avatar
Nice color on that set.
Bewitched always looks great on a roundie.
Old 08-18-2010, 07:29 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
So was it determined the old flyback was not original? Or was the old flyback defective, causing the various problems before? Very nice looking set, and great looking picture!
Gilbert
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 08-19-2010, 08:27 AM
droptop's Avatar
droptop droptop is offline
Behind in Time
The flyback was original to the set. Once removed each winding was rung on two different flyback testers both of which indicated a shorted winding feeding the horizontal yoke section. Resistance of this winding was checked against the schematic values and found to measure 5.2 ohms where 9.4 was the correct value. The interesting aspect to this was that the flyback didn’t run hot and could be adjusted to as high as 26 KV but at no time would it focus properly. It was very close but still a little soft. With the new flyback in place focus is achieve with the control almost center of its range.
Old 08-19-2010, 09:09 AM
was the HOT cat current hi with the bad fly?
Old 08-19-2010, 12:56 PM
droptop's Avatar
Behind in Time
Slightly. With correct settings of the linearity slug instructions called for a max of 180 ma w/o drive lines present but it ran 185 at the lowest drive setting and would go up around 200 easily.
