Old 06-19-2010, 11:46 AM
roundscreen roundscreen is offline
Ct-100
Hi guys
There is a ct-100 for sale in Tonawanda NY. The set is complete other than the hi voltage cage cover and some tubes. I did take the hardware off the crt but could not find anything that looked like the getter. Not even the milky white one you would see if the tube went to air?? I did not want to fire up the crt heaters in case the tube had air in it. The owner seemed cool about doing it but did not want to take the risk. As you can see the cabinet has water damage but the chassis is not rusted that bad. It needs a lot of work but is one cool set. The owners name is Allen and his E mail is allenroth at juno.com.
Good luck and I hope one of you guys on here gets it.
Ed
Old 06-19-2010, 12:21 PM
John Folsom's Avatar
Interesting channel indicator knob on that CT-100. Looks like the one used on the model-5....?
John Folsom
Old 06-19-2010, 02:45 PM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Getter flashes on a 15GP22 are sometimes quite small in comparison to what you might expect. My gut says this may be an early production set. Sure would like to know the chassis serial number: B800???? or even possibly B111????.
Old 06-19-2010, 05:35 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Looks like a good project set for some serious restorer. I believe Ed means Tonawanda, N.Y. near Buffalo. Ed, perhaps you could post the serial # and cabinet #'s as Pete mentioned.
Thanks,
-Steve D.
Old 06-19-2010, 09:53 PM
Thanks,
-Steve D.
The chassis is a ct2B and the number on the cabinet is 805. I did not see any other numbers on the chassis.
Sorry about the spelling.
Ed
Old 06-19-2010, 10:28 PM
The chassis serial number is stamped in the metal under the big flat resistor on the back. The one in this photo starts with B800.
http://antiqueradio.org/art/RCACT-10...rialNumber.jpg
Phil
Old 06-19-2010, 10:46 PM
"The chassis is a ct2B and the number on the cabinet is 805."
ct 2b??? are you sure? I think that Ctc2B is the 21" version of the set.
The serial number is located below the big power resistor on the back of the chassis... sorta visible in the contrast enhanced picture. It can be seen even when the back is in place, through a little window.
Update... I see Phil beat me with a better pix... oh well!
Old 06-19-2010, 11:09 PM
freakaftr8's Avatar
Convergence freak!
Lucky guys, how are all these CT100's showing up all the sudden??
Old 06-19-2010, 11:40 PM
The Klingons, Borg, Romulans, & Talosians have all finished using them for their experiments....(grin)
Old 06-20-2010, 03:48 AM
Smile
Maybe because analog OTA TV is no more?
Old 06-20-2010, 04:26 PM
Hi guys.
Here is the deal, I am going over to look at the ct 100 on Tuesday. Allen wants me to fire up the crt heaters and see if the tube is any good. Also I will get the serial # and re check the ct #. When I get the results I will post on here.
Ed
Old 06-22-2010, 06:20 PM
tvdude1 tvdude1 is offline
ct 100
I called the guy today. he wants 5000.00. Guess I will keep my ctc4 .
Old 06-22-2010, 07:02 PM
That price is a little steep but if I had a crt for it I would have bought it when I first went to see it. Times are tough and Allen needs money like we all do.
The SN on the set is B8002175.
Ed
Old 06-22-2010, 08:32 PM
ohohyodafarted's Avatar
Bob Galanter
I emailed him a few day ago. He replied that the getters were milky white. The tube is ovbiously full of air. $5000 is way out in left field price wise. A nice restored set with a good crt, went for about $5K last year on e-bay.
I think Allen will be sitting on his set for quite some time until he gets real bout the price.
ME http://AntiqueTvGuy.com
Old 06-22-2010, 09:24 PM
ct 100
Harry Posters ctc4 at 1550.00 was better deal and more reliable.. Also crts are around.
