Old 11-03-2009, 06:22 AM
blue_lateral's Avatar
Digital Converter Boxes
Hello Everyone,
I have a some questions for those of you who bought TV converter boxes with a coupon.
You may wonder why I am asking now. Our situation here is a little different than most areas. Every station here is either a translator, or low power. Under the rules, all of them were exempt from the changeover deadline. Eventually they will be required to convert. One station here has a build permit from the FCC for a digital installation. As far as I know, they haven't started yet. We are surrounded by mountains, and as of right now there are no digital signals available over the air. Not one.
I waited as long as I could to request the coupons. I applied in the last few days of the program. Now the coupons are about to expire. We will need converters here, analog is going away, just not yet. When I get these things home, I wont even be able to test them.
I am now wondering what you think of the one you bought.
I have two coupons. One box will be for the living room. Analog pass through needs to work on this one, because at first there will be only one digital signal. The second box will be my workshop's cable system. It is currently fed by an old VCR acting as an NTSC tuner. I use this for working on vintage tv sets, so decent video and sound is important. Analog pass through would be nice, but not absolutely necessary. It does need to work well with older sets, because that is what it will be used for.
I don't think I need 12v capability, but If you have one of those, I would still like to hear about it's performance.
So... Here's the laundry list of questions. What model do you have and how do you like it? Does it have analog pass-through? Does your sound work right on an early set? How is the video quality? Is the sound in sync? Did it break after two weeks? What sort of output jacks does it have? Has your opinion changed after living with it a while?
Any advice would be appreciated....
Thanks,
John
Old 11-03-2009, 10:13 AM
jlw37663 jlw37663 is offline
I would recommend the boxes made by LG/Zenith if you can find them. I bought a Zenith DTT900 and an Insignia (identical to the DTT900) early on with the coupon program. I later added two Zenith DTT901 units (reduced in price at Sears and Kmart) without using coupons. The DTT901 has added analog pass-through and they seem to have made improvements to the audio line out levels (low on early models).
If you haven't already done so then you might want to look at discussion of these boxes and others at AVS and WTFDA (TV dx fans) forums. I did some on-line research of the early boxes, and the LG/Zenith made boxes seem to have the edge. Availability of CECB units in the retail market has now become a problem for many from what I am reading (particularly for some of the better performing brands). Production has apparently ceased on many.
I haven't had reason to regret my choice. The Zenith DTT901 and DTT900 seem to have better "sensitivity" than earlier HD boxes I have used from Motorola and Accurian/DigitalStream (Radio Shack) in this mountainous region, In mountains "sensitivity" on these is more an issue of how well they handle multi-path signal than ability to detect very weak signals.
Old 11-03-2009, 10:34 AM
000
Old 11-03-2009, 12:38 PM
ctc17 ctc17 is offline
I like the rca. I hate the wall wart part but the apex that has a built in power supply gets so hot theres no way it will last. The rca runs cool and seems to have a better tuner than the others.
Antenna is everything as usual. A local electronics store still carries winegaurd and I went though the spec sheets and found one with really good relativity equal gain on all channels. It works really well and makes all the difference in the world.
Old 11-03-2009, 01:57 PM
got a TR-40, seems to have random power up issues, needs a pretty strong signal. I would not recommend it if you are in a rurual setting unless you invest in a GOOD antenna, what ever that is. Mine is on rabbit ears, and a powered antenna. Granted they stink so that is prob the main problem. The random power issues seem to be a software issue.
Old 11-03-2009, 02:09 PM
If you need analog pass-through, get the Zenith DTT901 or the Insignia NS-DXA1-APT. If you don't need pass-through, you can also get the Zenith DTT900, Insignia NS-DXA1, or Channel Master CM7000. Don't bother with any others.
The Channel Master should still be available from Fry's Electronics, the others you will need to find from used sources, most likely.
Old 11-03-2009, 03:36 PM
Zenith26kc20's Avatar
Digital Stream, Insignia, Zenith (Insignia and Zenith are the same box) in that order. All mine are still going. Sound not always synced but no way to adjust. Mine work good on all my older sets, even the Motorola TS-4.
Stay away from Magnavox and Philco. Those two die real fast.
Old 11-03-2009, 04:11 PM
I think ratshack may still carry the digitalstream boxes. The Zenith/Insignia boxes are NLA except from places like ebay and other sources of used electronics. Like others have said; try to avoid the Magnavox, Philco, and Apex boxes. I know people who have had Magnavox boxes for over a year and they are still going; but, I don't like the cheap build quality and the fact that they are not as sensitive as the others. The Apex box gets hot enough to fry an egg on top of it.
Old 11-03-2009, 04:15 PM
site123a site123a is offline
I suggest you take a look at this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1183648
Old 11-03-2009, 07:48 PM
peverett peverett is offline
I have had the best luck with the Digital Stream ones from Radio Shack. These are still listed on their website. They are about $10 more expensive than some of the othere, but it has been my experience that their reception is better than the others I have tried. They also run cooler and seem not to cause very much buzz on tube type TV sound systems.
http://www.radioshack.com/product/in...ductId=3150939
Old 11-03-2009, 09:19 PM
I like the Channel Master CM7000, as it has an Svideo output jack, so I could feed just luma to my early pre-color era B&W TV sets. See http://www.videokarma.org/showthread...28#post1990128 With no chroma dot crawl. And it makes a great picture on my S video equipped Sony TV set.
Old 11-03-2009, 11:17 PM
OvenMaster's Avatar
DTV blows
This. My Magnavox is 18 months old and has been rock solid reliable, but about as sensitive as a box of rocks, even with an amplified and rotatable outdoor antenna. I'm not sure if it's the box or the terrain or the trees, but jeez! When I do get a picture, it's beautiful, and the sound is always in sync. I use its line outputs to feed my Panasonic mono VCR; I use the VCR's RF modulator to feed the TV via RF.
Tom
Old 11-03-2009, 11:45 PM
I have an Insignia, 2 Digitalstreams and a Magnavox. And that is the order of preference I have. They really cut corners on the Maggie.
Old 11-03-2009, 11:50 PM
Another vote for the Channel Master CM 7000... and it is NOT made in China, mine is made in Bulgaria! (and the box is metal...Gasp!!) It seems to be slightly more sensitive for Dx than others that I have tried. The Zenith, IMHO is a close second, but has no S-Video output.
Old 11-04-2009, 12:15 AM
N9ZQA's Avatar
N9ZQA N9ZQA is offline
VK Member
What everybody else said...
I've got both an Insignia and Channel Master box. Both have roughly the same sensitivity, with the Channel Master being a little more finicky as far as required signal strength. The Insignia is nicer for older sets as the visual theme seems to be plainer and larger, while the Channel Master has a lot more information displayed on-screen. They seem to drive older sets nicely, and as Bob said, the CM has a S-video output, which can be used to drive older black and white sets. The Insignia remote is also a little simpler to use, with about half the buttons of the CM.
Setupwise, the Insignia allows for easier addition of channels after initial setup, as well as direct RF channel entry - good for DXing.
I've had both since around March '08, and they seem to be going strong. Both boxes are plugged into switched wall outlets with their respective sets, and powered off completely when not in use. I don't know if that helps, but I would think so.
They both outperform the Magnavox I used to have hands-down. I wound up giving the Magnavox to my father, who's in a slightly higher signal area and it seems to work fine there. Its interface is a lot less intuitive, and I couldn't ever get it to work satisfactorily here with my small indoor antenna.
-Jim
