Old 07-24-2009, 11:08 PM
Harry's got some more of the good stuff!
Like this beauty, there's also a Blond 5.
http://cgi.ebay.com/1959-remote-cont...3%3A1|294%3A50
http://cgi.ebay.com/1956-RCA-CTC-5B-...3%3A1|294%3A50
Old 07-25-2009, 03:13 AM
Adam's Avatar
Adam Adam is offline
I wish I was closer and could pick up that ctc-9. I don't think I've seen a remote 9 before. The cabinet looks more like the one used on the remote control ctc-7, but the remote is the same as the one on my ctc-10.
Old 07-25-2009, 07:19 AM
Oooooh, Lordy, them's PURTY !!
Old 07-25-2009, 12:45 PM
Gerardn3 Gerardn3 is offline
How do those early RCA remotes work? They appear to take a battery and have a round "bulb" or something at the front. Is it similar to Zenith's Flash-Matic system?
That CTC-9 is a really beautiful set.
Old 07-25-2009, 01:04 PM
Adam's Avatar
It's ultrasonic, but the remote's electronic, unlike Zenith's mechanical remotes.
Old 07-25-2009, 01:14 PM
Thanks, that's pretty cool. I hope those sets find nice homes and get restored to working order!
Old 07-25-2009, 01:50 PM
grimer's Avatar
grimer grimer is offline
Old 07-25-2009, 02:36 PM
Electrohome Electrohome is offline
Exclamation This CTC 5 has a 21CYP22 glass sub, not the original 21AXP22A CRT
This blond CTC 5 HAS a 21CYP22 replacement all-glass CRT subbed in place of the original 21AXP22A metal-cone CRT that was changed out sometime in this TV set's life. I got a 1956 RCA Westcott CTC 5 that's GOT the original 21AXP22A metal-cone CRT and there's also a greenish-gray color also to the original 1956 21AXP22A CRT as opposed to the more grayish color to the later Colorama and 21CYP22-type CRTs as seen here. The original 21AXP22A CRT also had a dimmer picture than the later Colorama and 21CYP22-type CRTs as well resulting in this CTC 5 losing it's original 21AXP22A CRT to this later 21CYP22 CRT that was most likely installed in the early to mid-1960's on this set. When looking at any CTC 5, check the CRT that it's the original
21AXP22A CRT and this will have a major impact on the value of that particular CTC 5 color set. If it's not a 21AXP22A CRT in that CTC 5, the CRT has been replaced and upgraded-simple as that. Another vintage color TV collecting tip from Electrome:-)
Old 07-25-2009, 07:24 PM
Over the years, I have had many 5's with a glass tube installed. It is a simple retrofit and easy job. You leave out the plastic cone and withdraw all purity magnets into their housings without removing them. Should you use a 21FBP22 sulphide (pea green) screen, it will have absolutely beautiful color with a very rich red.
julian
Old 07-26-2009, 06:28 PM
wiseguy wiseguy is offline
do you also have to change the yoke? or is the yoke i see on the neck of this 5 just have a newer rear yoke support from a newer ctc ?
Old 07-26-2009, 07:12 PM
I see the old mounting brackets on the sides, I think they did snap on a newer yoke cover that clamps to the CRT neck
Old 07-26-2009, 09:14 PM
rcaman's Avatar
rcaman rcaman is offline
i have the exact same ctc9 that is mint. and it works. steve
Old 07-26-2009, 10:54 PM
This appears to have the official RCA glass tube adapter kit, which I could not find for my 5 and therefore had to improvise in order to use a 21FJP22.
