Old 07-18-2009, 01:56 PM
#47 pilot lamps - still available?
I have a Zenith H-511 radio that uses a #47 pilot lamp. I'm wondering if these lamps are still available. I would like to have one or two spares on hand, as the H511 uses the pilot lamp as an inrush current limiter and is also an integral part of the power supply; if the bulb burns out it will cause the 35W4 rectifier tube to run hotter than normal, and could endanger the other tubes as well. I'll try Radio Shack, as the last time I needed a pilot light for my set (about six years ago, after the original burned out due to a deformed electrolytic filter capacitor) they had them in packs of two. However, with RS now being largely if not totally out of the consumer electronics business (their focus nowadays seems to be on computers, high-definition TV, and home theater gear), I'm not sure I'll have much luck finding anything much in the way of pilot lamps or any kind of small components.
Thanks in advance.
Old 07-18-2009, 02:22 PM
12J5's Avatar
12J5 12J5 is offline
AK Subscriber
Try Radio Shack: http://www.radioshack.com/search/ind...47%20lamp&sr=1
Old 07-18-2009, 02:40 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
Antique Electronic Supply www.tubesandmore.com has 'em.
I think that MAT Electronics does, too.
www.matelectronics.com
Our local hardware store has 'em, too...
all the best,
mrh
Old 07-18-2009, 09:32 PM
marty59's Avatar
marty59 marty59 is offline
Mouser has them too....#47 lamps are most common...
Old 07-18-2009, 09:58 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
As does Parts Express... Still a commonly used lamp in tube geetar amps.
Old 07-20-2009, 12:32 AM
dgwojo's Avatar
dgwojo dgwojo is offline
Away 8/14 -->8/16/2009
I'd use a 755, it will last 7 times as long, Dave.
11-Altec A7(515/802/511B/N501),Model 19(416/802/811B/N1201),Model 18(604-8H),604-8G,8K,604C,604E,Model 9,EV Interface D,LT12,Koss CM1030.
Soundcraftsmen MA5002,MA5002A,Pro-Power3.
Toshiba SD5700(8),SD4700(4),SD3750(9).
RCA 10 band EQ w/expander(3).
HK Citation 25(2),Mac C27,1700.
Marantz 2270(3),4300,2285B,2325,2226,2230,2240,2245,2250.
Lafayette LR1500TA(2),Allied 395(3),Pioneer SX1010,850.
Old 07-21-2009, 09:57 PM
sanford12's Avatar
sanford12 sanford12 is offline
Ace hardware too.
Martin Logan Motion LX16's & B&M 704's
ML Dynamo 300 sub
Outlaw RR2160
Empire 298 TT W/Denon 103 cart
Marantz CD6006, Pioneer DV-588 SACD
