Old 02-26-2005, 06:59 PM
mbates14 mbates14 is offline
the AGC/sync is getting worse and worse as the set plays.
First, the horizontal wouldnt lock. now, its starting to loose its vertical in spots.
If i go back to the color bar screen, like I had it before, now the vertical wont lock, and the horizontal is tearing. the hue is awful now.
I can get the vertical to stop rolling, but the picture is half and half with lines if I do that.
Any ideas? im starting to suspect the 6BA11, but I dont have that tube either. But I really need to check all the resistors and replace the caps in the AGC/Sync area. im definatly showing progressing trouble in the area.
Old 02-26-2005, 07:07 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Need to start changing caps, Bubba. The lytics are tired and starting to fade out fast. I know it ain't as easy as changing that tube, but, it's probably what you need. Even if you got everything straightened out today by swapping tubes, those old capacitors in there will die out soon as you keep running it.
Charlie Trahan
Old 02-26-2005, 11:37 PM
Hehe! I think someone in this forum is gonna be jelous! the arche-Watcher!
looks much better in person.
I found a 10meg-ohm resistor in the AGC/sync circuit that was reading over 22megohm. Replaced it, it improved alot, but not all the way, since the caps need changed.
Old 02-27-2005, 12:37 AM
Charlie's Avatar
On Land
Aww geez Edith... get me a beeah!
Charlie Trahan
Old 02-27-2005, 01:46 PM
Lol
