Old 05-28-2009, 01:44 PM
Trance88's Avatar
Trance88 Trance88 is offline
I need more vintage!!
The model no. is WP2132UW
My top vintage finds:
'84 MC-600 speakers
Old 05-28-2009, 08:06 PM
It's in sams 2167-1. I'll see if I have it.
Old 05-28-2009, 08:20 PM
Trance88's Avatar
Great! Thank you very much!
'84 MC-600 speakers
Old 05-28-2009, 08:27 PM
T102 is the 4.5 MHz trap adjustment. It's located inside a metal shield. To adjust, tune in a strong signal and set the contrast to maximum. Adjust the fine tuning until a beat patten is visible on the screen. Adjust T102 for minimum beat interference.
The sound IF coil is T201 and is located next to the audio IF/output IC201. To adjust, tune in a station and adjust for maximum sound. Reduce the signal strength at the antenna terminals until distortion appears. Continue reducing signal strength while adjusting T201 for minimum distortion.
Old 05-28-2009, 08:40 PM
Trance88's Avatar
Thanks, Is there an adjustment for horizontal position?
'84 MC-600 speakers
Old 05-28-2009, 09:48 PM
I can't find a horizontal position adjustment; but, there is a B+ adjustment. If this adjustment is off, it will effect the horizontal size. To adjust, connect a DC voltmeter to TP91, low side to ground. Adjust picture for minimum brightness. Adjust B+ adjust control (R808) for 130 VDC +/- 1.5 volts @ 120 volts AC applied to receiver. This control is located close to the flyback and B+ fuse.
It is important that the B+ be correct. Do not use the B+ adj. control to compensate for a horizontal width problem. Also, the condition of capacitors C511, C512, C517, and C518 will effect horizontal width.
Old 05-28-2009, 10:13 PM
Trance88's Avatar
The width is fine. I guess the screen is just slightly off center.
'84 MC-600 speakers
Old 05-30-2009, 02:22 PM
zenith2134's Avatar
I'd at least try adjusting the B+. That's good advice, IMO, since there will always be *some* circuit drift in a set of this age.
Old 06-01-2009, 07:49 PM
Trance88's Avatar
alrighty, I tried turning the B+ adjustment all the way down. The left edge of the picture fills the screen perfectly while the right edge doesn't take up the whole viewing area of the screen. All across the top of the screen shows flickering white dashes. I wish this thing had a horizontal position adjustment. That's all this thing needs to get it perfect.
'84 MC-600 speakers
Old 06-02-2009, 12:06 AM
zenith2134's Avatar
Okay so by turning the B+ VR all the way down it is affecting other things, like the vertical (hence the retrace) which is why radiotvnut noted that its the wrong adjustment for an excessively wide horizontal. Meaning it will not correct a positioning problem either.
My guess is that there could be dry caps and drifted resistors in the horizontal circuit probably near the HOT heatsink. But setting the b+ as directed will make it a lot easier to troubleshoot for sure.
Hey isn't this set a 13 incher?
Old 06-02-2009, 06:24 PM
Trance88's Avatar
Yeah, the B+ is I guess basically like a zoom adjust. Nope it is a 10".
'84 MC-600 speakers
Old 06-02-2009, 07:18 PM
You need to adjust the B+ for 130 volts and then troubleshoot any other areas that seem to be causing trouble. If the B+ is too low, it will cause problems. If it's too high, it will still cause problems. These problems include producing excessive HV (which could cause x-rays) and stressing other parts in the set (such as the flyback and CRT).
Old 06-02-2009, 10:27 PM
Trance88's Avatar
Yikes X-rays?!? Well, I don't have a volt meter so I just hope I have it adjusted properly. I have the screen adjusted so the picture just fills the entire screen. I guess I shouldn't touch anything else until I have the proper tools.
'84 MC-600 speakers
Old 06-03-2009, 12:42 AM
The cheapest little DMM from walmart or wherever will do just fine for this task. You should be able to pick one up for less than $20. I forgot to mention that these sets are supposed to have a shutdown circuit to kill the set should the HV run high enough to cause x-rays or other harm; but, these shutdown circuits sometimes fail to work. That's why it's always best to keep the B+ running at the factory specified level.
Old 06-04-2009, 11:26 AM
Trance88's Avatar
Well, I think I've already tripped that shutdown circuit once. I was adjusting the vertical hold and the TV went dead. I thought I killed it but I unplugged it and plugged it back in and it came back on.
'84 MC-600 speakers
